Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 345 posts ]  Go to page Previous 118 19 20 21 2235 Next
PostPosted: Mon Jul 27, 2015 3:15 am
Downloads not there....
Sorry - they are now!
PostPosted: Mon Jul 27, 2015 3:20 am
Try now.
PostPosted: Mon Jul 27, 2015 3:23 am
What happened with "True Peek". Also what is value?
PostPosted: Mon Jul 27, 2015 8:41 am
Looks like there is no effect of 1% reduced modulation , reported as change in this version. Now point of beginning is -70dB , was at -80 dB previous beta14 . Look red line on the picture , starts to fall wrong at -70. Turn back some pages ago to see how this line starts to go "wrong" at -105 dB in the "perfect version" - that`s what i call it :)
It`s getting worse . Looks like it`s not from modulation but from somewhere else . You can turn back this change , because this 1% has no effect on this issue.
Also "Ignore freqiencies" issue still there - both (jumping noise floor and unwanted moving spike signal)
PostPosted: Mon Jul 27, 2015 10:05 am
It is overruled by Stokkemask. Value depends on other settings - usually it will be the same as the slider to it's left.
PostPosted: Mon Jul 27, 2015 10:15 am
Are you using the stand alone version? Which output are you looking at and what is the Volume slider set to?
PostPosted: Mon Jul 27, 2015 11:39 am
Yes, Stand alone .
I`m looking FM output (whole MPX). And slider of this output is set to 100% ( 0.00 dB) . I try to set it to -1.00 dB , to -3.00 , but this (whole MPX) is just getting down by the amount of decibels WITHOUT change it`s shape . This on picture NOT disappears, stays the same but with less amplitude!
PostPosted: Mon Jul 27, 2015 11:40 am
Yes, Stand alone .
I`m looking FM output (whole MPX). And slider of this output is set to 100% ( 0.00 dB) . I try to set it to -1.00 dB , to -3.00 , but just this what you se on picture is getting down by the amount of decibels WITHOUT to change it`s shape . This on picture NOT disappears!
The noise floor jumps should disappear as soon as you lower it below 99%. I'm looking at the other issue now.
PostPosted: Mon Jul 27, 2015 11:50 am
Yes, Stand alone .
No, i test even this . Not disappeared even with 84.5 % ( around 1.40 dB lower). Even at -2.00 dB too. Same thing- just lower the whole signal by 2.00 dB and all jumping is same. Let say at 0.00 jumping is to -100 . With -2.00dB , jumping is to -98 . No any change in behavour.
These issues are in the forming of signal , not in it`s amplitude. I can prove all my words with video.
It can be easy tested , by enabling and disabling the Advanced clipper . When disabled , you will have to lower the output slider of FM to around -10 , -12 dB , because highs are "Free" and peaks will cause overmodulation. This will show up the slope shape with and without Advanced clipper. I must be clearly visible.
PostPosted: Mon Jul 27, 2015 1:19 pm
Ok, here is this
Video with clear difference that Advanced clipper causing all i`m talking about. I made output slider just how you tell me , even lower. No change . This is only for "over signal" issue . I can make one for jumping and spike to see it`s still there.
http://www81.zippyshare.com/v/pduRWTW2/file.html
Download it if not running from web.
