With a normal installer again! Images are now included in the binary, you CAN still change the skin, just make sure that the correct image is placed in the active directory and it will overrule the built-in image.
http://www.stereotool.com/download/ster ... 33-013.exe
http://www.stereotool.com/download/dsp_ ... 33-013.exe
Changes in this version:
- Fixed display delay. Now set at Configuration -> Plug-in -> Synchronize... setting for DSP version, in stand alone version selectable in sound cards window, default is 'normal output' (in Winamp that's the Synchronize... setting).
- Fixed black bars in AGC
- Improved display of input and output waveforms etc. - now synchronized and input and FM output are shown.
- Warning windows are back
- Cleaned up a bunch of memory blocks that were used earlier for displays but are replaced by new code.
- Show normal output waveform instead of FM waveform if FM is disabled.
- Include images in exe/dll so there's no need anymore to download zip files and copy them manually
To be done:
- Switching between screens: Button at wrong position.
- About, register, help (context sensitive, help button should be next to the preset buttons) What would be a logical place to put the registration stuff? I would think at the top of the Configuration menu...
- Make new minimized icon
- AGC 3rd band white not cleaned up
- AGC 2nd color not visible (swapped?)
- Bass Boost display incorrect
- Noise gate should be added to main overview (esp. since I saw it can give huge problems as it did in Leerdam).
- Probably more.... But I think I'm starting to get close!
