Post new topic  Reply to topic  [ 239 posts ]  Go to page Previous 118 19 20 21 2224 Next
 Post subject: Re: StudioOne HD / FM
PostPosted: Wed Dec 01, 2021 12:01 pm
@Bojcha
Wow! Adjusting 1st band in MB2 > mix out to +1db did wonders to the bass.
Left Bass clipper > Drive at +1.2db as before.
Also used the eq to tame the highs a bit.
I feel like i am getting there but you never know with stereotool so many options :oops:
When you have same spare time can you please listen to my Radio and make any suggestions. www.fradiogr.com
As always thank you for your valuable input! :D
PostPosted: Wed Dec 01, 2021 12:26 pm
@Bojcha
Yep, i left not one option for easy bass tune :) Also that and everything else i maded as much as possible simple to fine tune.
I was listening that stream yesterday it was just fine. Idk what bitrate is and codec but it's just fine, except i noiticed cut at around 16kHz ;) For that type of music i think Drive in bass clipper is more convenient. 1st band in MB2 bass is bit more up in freq and covers more bass.
Will try to listen more.. direct link to stream will also help :)
Currently i am making -11LUFS version of preset that one person requested, now i like what i hear :D https://i.imgur.com/YqxQK1D.jpg
PostPosted: Wed Dec 01, 2021 12:48 pm
@Bojcha
HPF is now set at 20khz
https://stream.zeno.fm/78pga7pvwk8uv 192kbps AAC
Also on the site i have a transcoded stream for mobile usage.
https://stream.zeno.fm/rrkxvddznp8uv 64kbps AAC
Do you think i will get any benefit by using ACR stereo effect or i should not bother?
Regarding LUFS i tried to follow in the begining but it got a bit confusing.
Now my go to tool for measuring loudness is to be able to hear the music properly in my car stereo with the windows open! :P
PostPosted: Fri Dec 03, 2021 10:32 pm
Incredible Update!
Anyway, I just cannot believe the difference in Sound Between Clipper (which I generally prefer) and Limiter (incredible Difference in high). Please, what would you suggest to give more highs with the clipper?
Thanks in advance
PostPosted: Sat Dec 04, 2021 10:32 am
Update! :D
I have to finally say i am quite satisfied with the outcome.
Thanks everyone for their help. ;)
I setup my own Icecast server as it sounds a lot better. (don't known if any further processing was happening from provider's side)
Now i only use the provider as a relay for the transcoded streams.
Sadly i can't use Vorbis as i have some issues with metadata not showing propertly.
Stream is now MP3 variable bit rate maximun 256kbps
Direct link: https://strm.fradiogr.com/frgr
Any suggestions always welcome.
If anyone intrested PM me to send you the settings.
PostPosted: Sat Dec 04, 2021 7:41 pm
Update! :D
Still 16kHz cut
PostPosted: Sun Dec 05, 2021 7:02 am
Update! :D
If you use the auto DJ mode in Zeno your streaming is re encoded and lost quality. For avoid this you need to set your streaming in “streaming” mode in Zeno.
https://fmfeeling.com
PostPosted: Mon Dec 06, 2021 11:52 am
@Bojcha
In the beginning you got me woried.
I suspect that cut is from the mp3 streaming bitrate i checked by chaning bitrate on the Streaming output.
128 kbit/s the is a cut a 16kHz
https://ibb.co/Csmbw82
192 kbit/s the cut ruffly at 18kHz
https://ibb.co/4JjQ6cr
On the original mp3 320 kbit/s file the cut is ruffly at 20kHz
Now i set up the stream as CBR 192kbit/s and bandpas filter is at 19kHz
As by no means i am an expert can you please check now and let me know.
Regarding Zeno i do not use the AutoDJ.
PostPosted: Mon Dec 06, 2021 12:40 pm
Now it's ~18kHz.
PostPosted: Mon Dec 06, 2021 3:23 pm
Now it's ~18kHz.
Perfect thank you! :roll:
A few posts back you said you made a -11Lufs Version can you share? 8-)
