Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 758 posts ]  Go to page Previous 118 19 20 21 2276 Next
PostPosted: Fri Feb 16, 2018 7:18 pm
My guess would be that this is some optimization/compiler bug. Otherwise everyone would see this.
What CPU do you have (exact type), which Windows version and which build of the software are you running?
O, and how did you make those GIFs? ;)
PostPosted: Fri Feb 16, 2018 7:30 pm
Oh, excuse me. I knew I forgot to mention something, that was it... :roll:
I tested the VST 64 bit version under Windows in Adobe Audition CC 2018.
I did it with the ScreenToGif tool. This is very useful and is also available as a portable version for download. This is free of charge and available under an open source license.
http://www.screentogif.com/
PostPosted: Fri Feb 16, 2018 8:01 pm
I'm having a similar problem to that Near05 reports, the AGC reduces volume, but it doesn't increase it properly when using the "new AGC mode", I kept playing with the settings and managed to fix it, increasing the Release time and reducing the Attack time a bit from the default settings, you can see how it looks here:
So I guess it's working but something got changed from the legacy mode.
I'm using the winamp plugin version in Windows 64-bits, if you need more information, I'll be glad to share, thank you!
PostPosted: Fri Feb 16, 2018 9:11 pm
Ok something appears to be wrong with "Max release speed" - if you set it to the maximum it works fine, any lower value blocks release completely. Will check why.
Max attack works fine though. By the way, you shouldn't really need Max Release Speed anymore because the release speed is no longer excessively fast on loud bursts.
PostPosted: Fri Feb 16, 2018 9:31 pm
Just to note, on "Low Level Boost," Max Release Speed's default setting is below maximum.
PostPosted: Fri Feb 16, 2018 9:37 pm
Thank you for this information. I tried it once, and it actually works. Exactly this setting had now been in the preset of weskeene. So that was the difference, and because it is not at maximum by default, nothing seems to have happened.
By the way, with the new beta, I also have crashes of Adobe Audition every now and then when I open StereoTool. This is rather irregular, but then the whole program crashes.
Name of the application with errors: Adobe Audition CC. exe, version: 11.0.1.49, timestamp: 0x5a545b16
Name of the faulty module: vst_stereo_tool_64_BETA855-028. dll, version: 0.0.0.0.0, timestamp: 0x5a8607ae
Exception code: 0xc0000005
Error offset: 0x00000000000028c61a7
ID of the incorrect process: 0x2784
Start time of the faulty application: 0x01d3a763478e1a42
Path of the incorrect application: C: \Program Files\Adobe\Adobe Audition CC 2018\Adobe Audition CC. exe
Path of the faulty module: C: \Program Files\VstPlugins\vst_stereo_tool_64_BETA855-028. dll
Report identifier: 8bc4e166-c196-461a-b864-cae317ec9aef
Complete name of the incorrect package:
Application ID that is relative to the incorrect package:
Problem Events: APPCRASH
Application name: Adobe Audition CC. exe
Application version: 11.0.1.49
Application time stamp: 5a545b16
Error module name: vst_stereo_tool_64_BETA855-028. dll
Error module version: 0.0.0.0.0
Error module timestamp: 5a8607ae
Exception code: c0000005
Exception offset: 00000000028c61a7
Operating system version: 10.0.16299.2.0.0.0.768.101
Locale ID: 1031
Additional information 1: c4b6
Additional information 2: c4b69e2e18eaa63e51b98ea400746398
Additional information 3: e259
Additional information 4: e259861a230e7103057252533b493b9f16
PostPosted: Fri Feb 16, 2018 9:46 pm
Ok max release speed appears to be inverted. If I lower the setting it allows more stuff to get through.....
PostPosted: Fri Feb 16, 2018 9:55 pm
Hans the max release speed starts to work when you turn it up nearly all the way. It seems to get stuck around the default point.
Fidelity over loudness
PostPosted: Fri Feb 16, 2018 10:16 pm
All the way up it bypasses a piece of the code (to lower the CPU load), so then it just completely ignores it.
PostPosted: Fri Feb 16, 2018 10:59 pm
Another question about the new mode of the AGC. Is the pre-AGC still needed for these? As I understood your description, the new symmetric detection should be able to cope with large level differences. So I am wondering, do you really need the pre-AGC? If so, do you have any suggestions on how to set it for symmetric mode?
