Yes, AGC1 in beta2 is bit different then in beta and i did't go deep into what is differences, that is why i said to load
preset in beta. It did not act same as in beta 2 with same AGC1 only.
That combination agc1/2 is better for filling some gaps and even without RMSing tracks are more matched in rms level.
But i don't like when sometimes 2nd agc is going up too much and make some quiet parts in track too much loud.
Maybe it still need some super-precise setting but i only tryed what you suggest as default for beta2 agc.
Intereseting is that with this two AGCs there is still no pumping .. just leveling.
Problem is in recovering down speed emidiatly.. not up-speed when the tone is already down ...
huh .. should be
immediately lol
some Voice parts are lowered (leveled) by agc that's ok.. but in some moments it is lowered more .. and interesting is that same "more lowered parts" in original source are Higher. So, with this AGCs faster up speed is not solution because and agc1 and agc2 is lowering this parts in same manner. You can add 5 like this AGCs in line and all will be again same.
Maybe solution is multiband ? i already said that something is not good in multiband. Many ideas are on my mind...
Less bands? Joining some bands? beter choice of freqs.? Better filters? Add separate compress vs limit for each band ? Cross over output mix for bands? or whatever...i already get (i think) better results with some multiband settings.
i already said .. i would like to know how this can be done, but i don't.
what is read and saw, is that AGC in processors have compressors, wideband compressor, side-chain compressor, Parametric EQs even Limiter.. all that in AGC.
..and what is WideBand exactly.. definition..(?)
I am not ashamed to ask things that i don't know .. if someone can answer then there is guaranteed solution not only for AGC but for all processing. But that is something like TOP Secret.
in few minutes i'll upluad 2 tracks, One is Stereo tool and one is other processor
edit: Here it is:
1. Stereo Tool Web Stereo Preset, 2xAGCs (Hans's sugessted default settings), lowered Final Limiter to match other processor
2. other processor
http://www50.zippyshare.com/v/56016512/file.html
