Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 233 posts ]  Go to page Previous 117 18 19 20 2124 Next
PostPosted: Tue Nov 03, 2015 7:48 am
I don`t see any clipping level in the Normal output ?
For what cllipping level we talk about - bass clipping, highs clipping or all volume clipping ?
PostPosted: Tue Nov 03, 2015 9:27 am
I just got the NAN error in the Natural dynamics . I play with the frequency bands sliders fast (left right) and it gave me the error at the last two sliders (band 8,9). But i think it can give it at other bands too.
The different thing here was that error is not looping. I press CLOSE and ST continue to work. The strange thing is that when i got this error (every time) the sound is affected like boost and reduce the whole level and then again it goes to what it should be.
Ok , start with the default ND frequencies, then make them like in my video, just slide to the next band frequency limit or to the previous band frq limit . You can see what band to what limit is slided in the video.
Then start to play with the band i played.... voila. But make sure you slide it fast and a couple of times ( i don`t know may be needed 5-10 times to get the error).
Check out the video:
http://www58.zippyshare.com/v/eMkIH9ux/file.html
Hope this helps
PostPosted: Tue Nov 03, 2015 9:37 am
BIYF DIFF mode works fine in beta 022
PostPosted: Tue Nov 03, 2015 9:51 am
TO BE DONE (not fixed, at least in winamp plugin):
  1. Quote:
    Is this fix supposed to be part of beta 13 or does it belong to some other branch yet to come?
    Edit: O, I didn't notice that fix was a link when I read your post on my phone. Yes that fix should be in here...
  2. X-Overs depend on sample rate.
  3. NaN in black gate. Still trying to figure out what I've done to trigger this, though.
PostPosted: Tue Nov 03, 2015 10:20 am
  1. Quote:
Look at my video - it`s all there and i get the NAN every time i do this. Just slide some bands to the up next limit frequency and make them 2 or 3 one after another equal in frequency.
@Hans!! I got that NAN again , but this time is NOT recoverable . it`s looping.
PostPosted: Tue Nov 03, 2015 10:40 am
Hello,
Would it be possible to allow different thresholds for the bass range vs. the rest of the Signal in the Pre-Limiter of the Clipper section?
PostPosted: Tue Nov 03, 2015 12:19 pm
BETA774-021
- Bass In Your Face: Rename to Warm Bass
Is it an idea to move and combine it with the 'Bass Boost' section in stead of creating another one? There are so many sections already.
PostPosted: Tue Nov 03, 2015 2:48 pm
Hello,
I'm actually not even really sure if the pre-limiter is still useful after the improvements that I made to the clipper together wtih Leif? Does it do anything useful now?
PostPosted: Tue Nov 03, 2015 2:49 pm
BETA774-021
True... Only thing is that Warm Bass is before the bandpass filter, and Bass Boost is after. :( Let me think about this...
PostPosted: Tue Nov 03, 2015 3:13 pm
Hope this helps
Just tried it for several minutes without any occurrence of this. :(
Edit: Same code is called from 2 different locations, that might be bad - I've put a mutex around it. Hope that helps.
