Post new topic  Reply to topic  [ 257 posts ]  Go to page Previous 117 18 19 20 2126 Next
PostPosted: Thu Sep 29, 2022 9:57 am
Update I just deleted the ini file re-imported my preset and now things seem to work fine.
Oh! I assume you didn't keep a backup? Because if we can reproduce it here we can fix it.
PostPosted: Thu Sep 29, 2022 7:28 pm
Yes I did keep a backup and here it is
@the8trackkid
Please, delete these attachments, for safety reasons to yourself. :shock:
PostPosted: Thu Sep 29, 2022 7:31 pm
I've downloaded both, but I don't see crashes here. Just to make sure: The old MB compressor isn't enabled in these, so I had to enable it first. Is that what you expected?
PostPosted: Thu Sep 29, 2022 8:04 pm
Hi Hans, where is the new software STudio? :roll:
PostPosted: Thu Sep 29, 2022 9:28 pm
Sorry about the reg key :(
Fidelity over loudness
PostPosted: Thu Sep 29, 2022 9:39 pm
I want to apologize for my mistake there :oops:
PostPosted: Fri Sep 30, 2022 10:38 am
viewtopic.php?f=14&t=32883&start=30
But wait an hour or so, I will post an updated SD card image in 1-2 hours.
PostPosted: Fri Sep 30, 2022 9:26 pm
There is strange bug in multiband "band coupling" - Tested with old gui standalone latest Beta60/61
Load Web preset, go to MB1 and set "band coupling" to anything then 0 then set it back to 0 again. BUG. It fixes after ST restart. It happens almost with all presets actually. In Beta58 it does not happen.
PostPosted: Fri Sep 30, 2022 9:46 pm
I think that this is part of the compressor bug that I fixed (last night's build failed, so I couldn't post it yet). Coming tomorrow morning!
PostPosted: Sat Oct 01, 2022 1:44 pm
BETA062 is available, for people using any beta's since 058, please update to this one, because a lot of stuff was broken in the compressors, AGC, Natural Dynamics, Auto EQ, Sub Bass Boost and I'm probably forgetting some. This didn't affect anything on startup, but changes in parameters weren't handled correctly.
New product: MicroMPX AM Reprocessor. This has a very specific purpose: Lots of stations in the US need to run both FM and AM, where the AM is basically what gives them the right to run on FM, but they need to transmit the same content, and 99% of listeners will be listening to the FM signal. So they would need 2 separate streaming methods: MicroMPX for FM and something else for AM. This Reprocessor takes the mono output from MicroMPX, lowpass-filters it, boosts the level a bit (since all the highs and stereo are gone) and then clips it - asyemmtrically if needed. It's clearly not the best possible solution - but it's very simple to set up. (If there's a lot of interest in this we might at some point create a MicroAM codec, that is explicitly NOT what this is). Can be found in viewtopic.php?f=14&t=32883&p=72462#p72462 .
