| Site Admin |
BETA116:
- Strict bass clipping maximum 6 steps (baires, please test the performance!).
- Advanced Extreme Highs Protection re-enabled. (New implementation!)
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-116.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-116.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-116.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-116.dll
Command line version: http://www.stereotool.com/download/ster ... 20-116.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-116 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-116 NOT AVAILABLE
- Fix Punch
- Loudness: Annoying cracking sound in bass. Slightly present in 5.00, worse in 6.00, maybe even worse in 6.10. Only when bass is too loud. Much worse than in Final Limiter (at same input level!) - so this clearly indicates a bug. Most likely cause: The filter that was added to remove bass artifacts....... - No, it's the louder bass. But it can be fixed by changing some settings. Default settings updated, and behavior for 'not Very strict' improved. Also Deep bass boost and Very deep bass protection are enabled for latency 512 now.
- Fix crash at program close
- Reduce Loudness CPU load
- Scopes black background?
- Add AGC start level
- Save bandpass filter order
- Fix Loudness display
- Smarter lows volume drop against highs protection: First clip using reduced highs (highs protection filter), then do it again but do NOT lower the lows below the level found in the 1st step. - NO! No longer needed.
- Optimize clipper code: Reflection, smaller overlap (stronger reflection possible?); optimize RMS search filter; optimize voice vibration removal
- HPF bad since BETA080, especially with declipper enabled
- Highs vs bass distortion protection: Fix window edges.
- Add highs distortion sensitivity slider(s)?
- AGC hangups
- DC caused by clipper
- Fix pre-ringing artifacts
- Checkbox to combine bands 1+2 of Multiband
- Phase linear highpass filter if non-phase-linear is selected to avoid DC offset.
- Extra HPF step either just before Singleband or - if that's not used - after the bass protections for Loudness. Maybe also for phase linear HPF! AVAILABLE, WAITING FOR FEEDBACK
- Remove or simplify 'Advanced highs protection', look at other protection mechanisms.
- Robot effect when changing to lower latency (?)
- Save new clipper, bandpass, multiband options (STS+VST)
- Release 1 hour
- Add composite clipper
