Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 116 17 18 19 2059 Next
PostPosted: Fri Feb 12, 2016 10:40 pm
playing some music with the latest beta... and the latest Minnesota Twin Cities, which i'll release soon. Absolute Highs is enabled, as it will be in Minnesota by default now. I've also changed from the Simple Clipper, to the Advanced Clipper.
http://stream.masterfulaudio.com:7911/listen.pls
I haven't played with the "Pass squeeks" setting yet, but otherwise I've found the following settings to be ideal for set & forget:
For an oldies station, you might want to drop the two frequency sliders, but *never* drop the lower frequency slider below 5kHz at the extreme, 7kHz is a better idea. And *never* put the two sliders closer than 300Hz at 5kHz. At 7kHz they should probably be around 450Hz apart or a bit more. There could probably be an "Auto" button for the higher frequency slider.
Also... "squeeks" is spelled wrong. It should be "squeaks". ;)
Hans, a feature request, that the Simple Clipper can be set to be enabled, but that it'll automatically disable if the Advanced Clipper is enabled. That way I can have Advanced Clipper enabled in the preset, and if someone disables Advanced Clipper, they won't have to know to enable the Simple Clipper.
Is there any use scenarios where someone would want both?
PostPosted: Fri Feb 12, 2016 10:58 pm
Something seems to have gone wrong in the stand alone build. I've just restarted it. Sorry!
PostPosted: Fri Feb 12, 2016 11:02 pm
@Jesse: Hm, does it sound good if you always enable it? I'll run some more tests, it might be. Anyway I am planning to add a 'Volume' slider that reduces the effect (and, if there's already stuff there, it doesn't do anthing in the first place, so lowering the effect just a bit can have a big effect on what comes out). With the recent changes the amount of highs that get added have increased by several dB's (mainly because I made the filtering out of unwanted sounds smarter), that's why I'm not sure if it still always sounds good.
I will remove the Squeaks setting. (Behavior will be as if it's set to 100%, not 200%!)
About simple clipper: If you enable both, only Advanced Clipper is used, but the volume difference that's set in Simple Clipper is still used. So, you can do what you want already!
PostPosted: Fri Feb 12, 2016 11:26 pm
030 stand alone has been re-uploaded!
PostPosted: Sat Feb 13, 2016 12:16 am
Hi Jesse.
You could include better true bass?
Pretty Girls in your city
PostPosted: Sat Feb 13, 2016 12:52 am
Yes, the latest Minnesota has different True Bass settings. 8-)
PostPosted: Sun Feb 14, 2016 8:54 pm
Wooh! It looks like I compiled Absolute Highs with a wrong flag set in the last beta. Which means that it didn't act as it should have!
Will run a new build asap.
PostPosted: Mon Feb 15, 2016 1:31 am
Wow this is unbelievable! By your recent changes the higher frequencies are incredibly great completed! The difference is really big!
You really did a awesome job!
So as it turns out I had a big bug in it. Let me know what you think of BETA031 (will post it in a few minutes).
PostPosted: Mon Feb 15, 2016 1:38 am
7.85 BETA031
Windows stand alone: http://www.stereotool.com/download/ster ... 85-031.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-031.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-031.dll
CHANGED:
- Exciter: Add Volume slider
- Exciter: Add DIFF mode
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Exciter: Make 2 kHz block size configurable, or automatic, or combination. Might work best if it's constant??
- Voice protection in classic MB is broken. Check what changed. (Code should not have changed at all). - Hm, more has changed. Check in which version! -> Waiting for reply to question
- Exciter: Add auto-adjust frequency
- Exciter: Improve further, and make it configurable.
- Add Polar stereo viewtopic.php?f=16&t=6233&p=33031#p33031
- MP3?
LATER:
- O skin
PostPosted: Mon Feb 15, 2016 6:07 pm
I tried the latest version now. In the example, from the very beginning of development, I now get but a few very shrill sounds. That hurts when listening a bit. I send you via PM once the file and my settings used, so you can adjust it.
