Post new topic  Reply to topic  [ 292 posts ]  Go to page Previous 116 17 18 19 2030 Next
PostPosted: Fri Nov 22, 2013 3:51 pm
And i wonder why you use two separate programs ?
Why not you use one time and for FM you choose FM card and for web stream you use Normal output card for web stream ?
Why you torture you computer two times ? Only because different settings ? Man wake up :)
you are not pro :p
btw, ofc it"s not because settings only.
PostPosted: Fri Nov 22, 2013 4:13 pm
@DOGGY
1st pc are for torture.!
2nd The stream sound no need to be compressed.!
PostPosted: Fri Nov 22, 2013 5:08 pm
@bojcha I'm in china??? Where are you? :P
LOOOOOOOOOOOOOOOOOL <3 :)
PostPosted: Sat Nov 23, 2013 7:40 am
Windows stand alone: http://www.stereotool.com/download/ster ... 32-020.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 32-020.exe
- Added sound card restart behavior in case of driver errors. No guarantee that it works (because I don't know if the problem that was reported by Storm905 viewtopic.php?f=2&t=5054 was caused by what I think it's caused by) - but it might.
Warning: Fix is tested for normal input and output, but not yet for ASIO. I'll do that when I'm back in my office on Monday. I expect it to work for ASIO - but it's always a bit risky if it hasn't been tested properly.
PostPosted: Tue Nov 26, 2013 9:01 pm
Found a graphical bug . Anyone see this behave ? without audio signal
This is on previous beta , not 20 .
http://www21.zippyshare.com/v/69648347/file.html
PostPosted: Thu Nov 28, 2013 3:48 am
In the Beta 20 the control MB -> Non-Standard -> Peak Smoothing, when you want to adjust, set maximum value to 1 ms. and you can not put more value.
Also, except RMS Block, grayed as if they were disabled.
@ hvz: Could you give a little more detail than Non-Standard Controls? :mrgreen:
by GAP
"Less is More" (Bob Katz)
PostPosted: Sun Dec 01, 2013 6:45 am
Just fyi...
"start minimized" flag doesn't save, or start minimized. Flag clears upon saving settings or restarting program.
PostPosted: Fri Dec 06, 2013 1:33 pm
Experimental new feature:
http://www.stereotool.com/download/ster ... 32-021.exe
Install VLC ( http://www.videolan.org/vlc/ ) on your system, in a DOS (cmd) box go to the VLC install directory (for example C:\Program Files (x86)\VideoLAN\VLC), and start Stereo Tool from there. Then look at the input options :)
In the next version I'll add an auto-detect feature so you can just start ST without needing to go through this command line stuff.
PostPosted: Fri Dec 06, 2013 1:40 pm
See this post: viewtopic.php?f=14&t=4989&start=134
In RMS mode most settings are indeed disabled. 3 of them are for Peak mode, one is for RMS mode.
I'll check the other reported issues.
PostPosted: Fri Dec 06, 2013 3:21 pm
Works, but how do I play something through ST? Do I need to select a special audio-output in VLC?
