Post new topic  Reply to topic  [ 193 posts ]  Go to page Previous 116 17 18 19 20 Next
PostPosted: Mon Apr 11, 2022 5:24 pm
Aaand median 'hide' gone.
PostPosted: Mon Apr 11, 2022 6:44 pm
That's now a central setting. Under Configuration -> Median displays.
PostPosted: Mon Apr 11, 2022 7:52 pm
ow, ok then :)
PostPosted: Thu Apr 14, 2022 8:58 am
BETA037 is posted. No really relevant changes for most people here, but this is probably the last beta before release. The only thing left on our release todo list right now is adding and updating presets, and updating the version numbers. So please let us know if you run into any issues.
PostPosted: Thu Apr 14, 2022 9:55 am
Beta 037 Legacy AGC reduction meter is not visible
PostPosted: Thu Apr 14, 2022 2:07 pm
Don't know it is intentional or not, DeReverb is still missing from Repair section. viewtopic.php?f=16&t=32086
PostPosted: Thu Apr 14, 2022 2:41 pm
The idea here was to make it available to the VST plugin and to anything that would normally be used for file processing or microphone processing. It didn't _seem_ to be that useful for the stand alone version. But, please convince me otherwise (I'm easy to convince) and I'll put it back in. It's a single line that determines whether it's there or not.
PostPosted: Thu Apr 14, 2022 3:16 pm
I often listens conversations with recording of bad circumstances, lots of reverb. This filter just pampered my ears, much more comfortable to listen this contents with DeReverb filter. I REALLY appreciate if you put this filter back.
Probably I will buy a license for this, even never will use the BIMP functions, if you promise this filter is stay here forever :)
Thanks!
PostPosted: Thu Apr 14, 2022 3:49 pm
The 1st band was missing. Should be fixed now (next build).
PostPosted: Thu Apr 14, 2022 4:19 pm
Thanks!
For more context: it doesn't appear in the Win x64 Standalone under Repair. But it does appear in the 32-bit VST2 under Repair. I think this user is using the standalone.
