StudioOne HD
StudioOne_v00.03_HD.sts
Update:
StudioOne_v00.14_HD.sts
Update.
After some time, here is last version i have.
Default HD version StudioOne_v01.70-HD.sts
Boosted HD version (bass and highs) StudioOne_v01.70-HD-Boost.sts
FM version StudioOne_v01.71-FM.sts
FM version - small fix for sub bass.StudioOne_v01.72-FM.sts
FM versionStudioOne_v01.73-FM.sts
Updated to version v1.74 (probably Final version). Some more tweaks to dynamic filter and other tweaks.
StudioOne_v1.74_RC1_HD-HD2-FM.rar
This new versiosn has new MB1 xovers and many other small fixes. Later i'll post boosted versions, it will be differently boosted
StudioOne_v01.94-HD-default.sts
StudioOne_v01.94-FM-default.sts
Be sure to load all audio and FM settings for FM version.
Since many will ask for more bass, it's very easy to add it, Bass Clipper > rise 'drive' (currently +0.4) For example i like it at +1.4dB
Latest version 1.99
StudioOne_v01.99-HD-FM-default.sts
Fixes: Mostly about AGC, it's faster now, protection compressor stronger, some distortions removed caused by MB2 on some tracks.. etc.
Latest and Final version 2.02 StereoTool 9.82+
StudioOne_v02.02-HD-FM-default.sts
Fixes: HD Output now uses Limiter, Final level also determined from limiter (before Hard Limit), i hope i fixed some distortions from MB2,
AutoEQ is set but OFF, some small fixes.
For FM usage i recommend HighPass Filter at 34Hz
- Using 130% quality! 150% is best, and 100% is still ok.
- Use no more than -3dB input. Up to -6dB is best. Ofc it'll work with 0dB input, but because AGC gate and Noise Reduction, ~-6 is kinda sweet spot.
Preset using clipper instead limiter (HD), since limiter is unfortunately broken. Yea.. Who does not notice, it's much better to use Limiter [for HD] (just turn it ON, all pre-adjusted) especially if it's for streaming.
- Who likes phase rotating, there is new one, much more resembles 'that' sound (Phase Delay). So just turn it ON, already set.
If anyone want more or less loudness, more or less bass/highs, etc.. ask how to do it properly.
Last Edit: 02.nov 2021.
Super presets! I have problem with the output sound, it’s sounds as a low quality mp3 output. ( kind of a muddy treble sound ). The rest frequencies are fine. The tracks that i play are 320.
Kindly help me to sort out this issue. Hope u understand my Sound engineering English
