Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 758 posts ]  Go to page Previous 116 17 18 19 2076 Next
PostPosted: Wed Feb 14, 2018 8:09 pm
How do you use the VLC stream input? I reinstalled VLC already. All I get is Stereo Tool basically hanging, and yellow "Stream restarted after ERROR!".
PostPosted: Wed Feb 14, 2018 11:00 pm
For me, I just put in the StreamURL the address I want to stream, its' really easy.
http://my.stream.site:5001/stream
Pretty simple.
You don't need to have VLC installed, it's "built into" Stereotool.
PostPosted: Thu Feb 15, 2018 5:41 pm
Okay. I inputted the stream address as you suggested, but it's still yellow.
Anyhow, another question: how can you increase the rate of polling a Radiotext file? It now takes about 30 seconds to respond to changes made in specified file. Linux btw. I recall that Windows version reacted much faster.
PostPosted: Thu Feb 15, 2018 6:15 pm
Can you try if you can open the stream in VLC itself?
This is also an option:
If necessary you can supply extra VLC command line arguments after the URL. For example --extraintf logger -vvv will show a logging window that might be useful to find out what's happening exactly (do not turn this on during normal usage because it can make things unstable). Other options can be used to control sample rate, buffering and more. For a full list of options (some can cause big problems when using them from within Stereo Tool) see VLC command line help.
New build (for Windows) is running, the Pi/Mac build is currently broken due to all the changes. This will take a few hours...
PostPosted: Thu Feb 15, 2018 6:16 pm
I have strapped myself in for the excitement :-)
PostPosted: Thu Feb 15, 2018 11:33 pm
Stereo Tool 8.55 BETA028
NOTE: KNOWN (REPORTED) ISSUES:
- Max release speed is broken! It works inverted, all the way up is still off. But close to that it stops release completely
- Symmetric modes are visible for Digital compressor but not implemented!
Windows stand alone: http://www.stereotool.com/download/ster ... 55-028.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 55-028.exe
VST: http://www.stereotool.com/download/vst_ ... 55-028.dll
New AGC mode MORE INFO BELOW!
- RDS: Add PTYN
- RDS: Add timeout for TA
- VST version no 4K
- Backup input - check stereo
New compressor mode info:
Important: The CPU load is really high right now. I will optimize it later.
Also important: You can't just enable this new mode and expect everything to be fine without changing the settings. For small level differences there won't be a difference, but there will be for big differences. You'll definitely notice the slower attack on big level jumps.
OLDER CHANGES:
- Self test crashes
- Put Bass EQ under license
- Added Basstardizer
- Add low input level warning
- Added ASIO latency setting.
NOTE: Bass EQ
- Classical preset
- NAN seen when switching to new compressor mode which also doesn't get recovered - silence afterwards. (Peak mode recovers it though).
- Optimize new compressor mode
- Make 9/9sg pilot generation smooth for external feeds for DARC etc.
- Bass mono fiter to reduce multipath
- NAB text & ads?
- Is pre AGC affecting audio levels? (With BS412) -> Not specifically for BS412, but it slightly reduces the level even if set a lot higher. Probably needs some offset.
- Aanvraag uren
- AM streaming output
- Add AM presets
- AF method B via UECP
- 18 Hz trigger tone
- Declipper check L-R effects
- Reduce extreme stereo
- Check out Butt
- Omnia.9 test/fix logging
- WatchCat website
- Triple stuff
- uMPX 24x2ch interface
- One bass page
- Talk to chip
- 2 jaar
- Fardau
- -24 dB side chain range?
PostPosted: Fri Feb 16, 2018 8:40 am
Well, what to say?
Input level bars are still not reacting to Pre amplifier changes.
GUI window size still doesn't consider increased font size on 4k monitors. Therefor all buttons can only show a few big letters.
And we were always annoyed by the ST installer trying to go online on install, but is it really necessary to force MS edge to open which isn't even the system default browser?
PostPosted: Fri Feb 16, 2018 9:39 am
They shouldn't?! Unless you mean the Gain sliders for the sound card/plugin input, but I tested those and they work.
Works fine on my end, otherwise I wouldn't have posted this version. Do you have a screenshot? And which version are you using, on what Windows version?
Hm, let me check why it chooses that. If I recall correctly the installer software has an option to open a browser, I don't know though why it chooses Edge over the standard.
PostPosted: Fri Feb 16, 2018 10:37 am
  1. I mean the green input level bars in the GUI (4k monitor, 144 dpi). When moving the Pre amplifier slider the output bars change accordingly but the input bars stay at 100% volume no matter what.
  2. The default GUI window and button size is exactly the same for 8.54 and 8.55. However before with 96 dpi the text fitted the buttons perfectly and now with 144 dpi it obviously doesn't. This is the Winamp plugin 8.55 beta 28 on Windows 10 RS3.
  3. I think the installer should at least ask me for consent before opening anything. Btw is the installer needed at all or can I just unpack it and put the ST dll at my wished location? The cpudesc.dll is only used for the installer and not needed for ST, right?
  4. What exactly does the symmetry slider make symmetric? What value makes it symmetric?
