Post new topic  Reply to topic  [ 259 posts ]  Go to page Previous 116 17 18 19 2026 Next
PostPosted: Fri Mar 17, 2017 3:36 pm
- Change slope calculation in MB??? Wait for feedback from Wes and Matt --> Yes, change it
What's that about?
The slopes in the MB don't follow the settings. At some point when I made this code I thought it would be useful to automatically compensate for how far the bands are apart. Well, it seems that I was very wrong about that.
PostPosted: Fri Mar 17, 2017 6:07 pm
IIRC the slopes are only correct if two bands are exactly one octave apart (Well, actually your definition seems to count from -6 dB instead from 0 dB as others do, so it still differs from the usual way). Of course we're compensating for your automatic compensation as well, so it'll probably be just a convenience thing. I'll wait and see if this will just be a GUI change or something else.
PostPosted: Fri Mar 17, 2017 6:10 pm
Yes, that's what it is. No effect on the audio *if* you compensate for it already.
PostPosted: Sat Mar 18, 2017 10:30 am
If ST could keep a given slope when moving two bands further apart in the GUI and everything else would be kept as is for compatibility, this would mean that you need to allow much higher slopes in the settings file. So new values and possibilities would arise. That would be a very welcome change. :D
(Or you could just restrict far away bands in the GUI to have only tiny slopes. That would be useless though. :cry:)
PostPosted: Sat Mar 18, 2017 9:31 pm
Windows stand alone: http://www.stereotool.com/download/ster ... 25-028.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 25-028.exe
VST: http://www.stereotool.com/download/vst_ ... 25-028.dll
- Linux plugin: Close and resize don't work.
- Linux plugin: Window close should call a callback in the Generic plugin.
- Fix for compiler bug (crash in 026)
- SST: Add widget with text for version number, preset name etc.
- Font stuff: Głośniki - display as Glosniki (file in C:\temp\hd_v7.sts)
- Linux version no GUI in Generic plugin - Rivendell. - Probably fixed (more tests needed)
- Put Wasapi cards on top, KS below that. Or, better, order them alphabetically!
- Fix mono Bypass output and drops.
- Fixed crash when switching to/from Bypass mode (threading issue)
- Make 'Ignore high frequencies' enabled by default on ARM.
- Add WASAPI mode that uses exclusive sound card control to set sample rate.
- Add real PEQ, with low/high shelves
- Put PEQ in SST interface
- Fixed bug in Bypass code that might have caused all kinds of weird things.
- Natural Dynamics: Changed the dB value calculation for "Reduce for jump above" (display only); changed default setting to 6 dB (instead of 13). This reduces the effect of ND if the input signal is more dynamic. With some more tweaks I can probably make it sound better.
- Raspberry Pi version: Stokkemask causes silence.
- Hard Limit: Check report of overshoots - Solved, at least for any logical situations
- Fixed daylight saving time bug introduced in 8.23.
- PFFFT resampler!!! YEAH! 20% CPU load reduction on the Pi :)
- Generic plugin in debug mode shows PEQ too often assert, why?
- In the AM configuration When we use Asymmetry, the output markers show the red color all the time even if with fm transmitter it continues to generate pilot tone at the AM output. As you can see in the attached figure. Thank you for your attention .... -> Fixed pilot issue, restored Headroom slider.
- It appears when RDS RT Text is sent to StereoTool and it contains a “/” that ST separates it into two messages. Is this how you intended it to work? PS Text doesn’t appear to be affected. -> Fixed (but PS should also have been affected, odd).
- The DSP-Plugin still works correct. But somehow some trial features are activated when i am using the commandlinetool. What you have to know is this, that i am also totaly blind so i cant use the interface for configuring. I allways thought that the commandlineversion uses the DSP_Stereo_Tool.ini created by the winamp-plugin to set the different options. I think something changed cause i am getting the message that the program cant find or cant read the dsp_stereo_tool settings in the user-folder. So the stereotool_cmd.exe uses some settings wich are not completely available in the free Version. So i am getting this two beeps every minute. -> Oops, it was accidentally using the .ini file without .ini at the end... so not the Winamp settings file (which is the default).
- Linux and Raspberry versions: Now linking PortAudio statically.
- Make PortAudio work properly on Linux - it works but with weird warnings and it takes a long time to start. -> Fixed by removing sample rate check on startup. --> Appears to be a PortAudio ALSA backend issue!!! For now, keep the Jack version as well.
- Allow Linux version no GUI to run on Raspberry Pi without X11. (Hm, Windows version probably too - already basically there for service). - TODO: Test if it really works
- Fixed: Raspberry Pi version: AGC, Multiband 1 & 2 and some other filters can cause dropsouts
- - Fixed: Raspberry Pi version: Clipper can cause silence
- Fixed: All versions: Using Composite Clipper with Strictness 1 or 2 + Hard Limit can cause weird drops in the audio. Fixed, Hard Limit works different from before now! (and sounds better! Hint: Use this same trick for all limiters!!!!!!)
- PortAudio linked statically on Mac
- GiPHouse build warnings
- PortAudio weird jumps in buffer filling and glitches
- Put all PortAudio calls in 1 thread - was needed for WASAPI
- Made PortAudio work on Mac - weird hack needed (?)
- Synchronize PortAudio input and output starts
- Make sure that in case of no input audio, the error is reported for the input. Added the watchdog tick to be always called when the callback is called, even if no audio is being played.
- Make buffer filling 50% on start - Wait for first input to return. Only then allow outputs. Also needed for VLC (so the delay can be big!) In fact, the best way might be to connect it to when the first callback of the input sound card happens... enable the other callbacks INSIDE that input callback. But if I do that I need special solutions for VLC and ASIO. And that won't take the calculation time into account, and it might actually be a good thing to take that into account to make the buffer at least not too empty.
- Updated PortAudio to latest version
- Added FM/HD synchronziation slider. You will hear glitches when adjusting it, but no complete dropouts as with changing the buffer size.
- Changed PortAudio callback block size to let PortAudio decide the best size. This might slightly reduce latency and also help against hiccups.
- Added display of supported sample rates (and MME) to sound card selection.
- SST help
- Delossifier Spectral hole filler CPU load is much higher in 8.23 than in 8.00 - no obvious change in the code. - Wasn't true, slightly optimized it anyway.
- Removed old WINMM audio card code, replaced by PortAudio.
- Change version number
- Try new limiter mechanism
- Add and update presets
- Add Wes' latest preset
- Implement EXTRA auto-tilt correction
- Test if FM lossy link protection improves reception!!! -> Yes! (But it does also reduce audio quality quite a lot).
- Possibly also lower latency (based on what I read it should be possible to get close to ASIO latency - thread priority must be set too in that case, both with a flag and a value).
- Check if BASS is usable for streaming...
- Limiters: Make same change as in Hard Limit (from l + l * .01 to l + .01).
- Compare Stokkemask vs Multipath Clipper
- Maybe support ISO 226 curves for AGC and other side chains instead of ITU1770? See http://www.sengpielaudio.com/Acoustics226-2003.pdf ; curves look similar to the "old" curves but less to the new ones.
- Send out RDS texts
- Fix 31N
- Show low input level warning for inputs below - say - around -9 dB or so. For extended periods. Reason; I hear on a local station here that they probably have a too low input level and they didn;'t know that that was a problemn, but the sound on one of the built-in presets wasn't as consistent as it should be, and some tracks sound muffled probably due to too much noise gating.
PostPosted: Sun Mar 19, 2017 1:16 am
Windows stand alone: http://www.stereotool.com/download/ster ... 25-030.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 25-030.exe
VST: http://www.stereotool.com/download/vst_ ... 25-030.dll
- Try new limiter mechanism - to test it disable 'Legacy mode' in the lmiter settings
- SST help
- Fixed slider behavior for values < 0 (clicking left/right, adjusting with cursor keys or mouse wheel, minimum value was not reachable)
- Fixed 'Flat tops' mode when 'Adjust slopes' is disabled.(left as-is for when this is enabled for compatibility reasons)
- Fixed weird jumps in band behavior when 'Adjust slopes' is disabled (left as-is for when this is enabled for compatibility reasons)
- Fix 31N
PostPosted: Sun Mar 19, 2017 8:59 am
Thanks for the MB slope change! Testing it now.
Two minor things: The 'compensate steepness ...' button is titled 'Median Display'. The maximum gain for the new PEQ is +12 dB but only -11.99 dB.
First results:
With flat tops the slopes are following the settings but flat tops > 50% shifts the band frequency to the left.
Without flat tops the slopes are still not following the settings. They are now to steep for distances above an octave.
PostPosted: Sun Mar 19, 2017 8:33 pm
New limiter improves my sound a lot, more transparent in highs!
Thanks!
PostPosted: Mon Mar 20, 2017 8:37 am
Two more: Tested 4 bands with flat tops.
  1. With automatic steepness compensation all slopes can be moved independently, never effecting the graph of the others. Without compensation only 'slope to 3' did effect others, all others are still working as before.
  2. Without compensation changing slopes may raises the intersection point above -6 dB.
All totally screwed up at the moment but it already seems to be very useful when it's fixed.
PostPosted: Mon Mar 20, 2017 1:03 pm
@ \_/: I think I've fixed all the issues that you reported, if I missed any please let me know (in that case please add a screenshot, I've fixed what I've seen so far).
See next beta (next post).
