| Site Admin |
BETA109:
- Added "pre-ringing filtering artifacts filter" - a filter that removes (reduces) artifacts caused by the pre-ringing filter when the phase linear HPF is used. Note: I would describe these as 'rrr rrr rrr' sounds like what DJ_DOGGY talked about, but I only heard them when some filters are enabled. Anyway, they are nearly gone now. The impact on the pre-ringing itself seems to be extremely small.
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-109.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-109.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-109.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-109.dll
Command line version: http://www.stereotool.com/download/ster ... 20-109.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-109 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-108 NOT AVAILABLE
- Fix Punch
- Loudness: Annoying cracking sound in bass. Slightly present in 5.00, worse in 6.00, maybe even worse in 6.10. Only when bass is too loud. Much worse than in Final Limiter (at same input level!) - so this clearly indicates a bug. Most likely cause: The filter that was added to remove bass artifacts....... - No, it's the louder bass. But it can be fixed by changing some settings. Default settings updated, and behavior for 'not Very strict' improved. Also Deep bass boost and Very deep bass protection are enabled for latency 512 now.
- Fix crash at program close
- Reduce Loudness CPU load
- Scopes black background?
- Add AGC start level
- Save bandpass filter order
- Fix Loudness display
- Smarter lows volume drop against highs protection: First clip using reduced highs (highs protection filter), then do it again but do NOT lower the lows below the level found in the 1st step. - NO! No longer needed.
- Optimize clipper code: Reflection, smaller overlap (stronger reflection possible?); optimize RMS search filter; optimize voice vibration removal
- HPF bad since BETA080, especially with declipper enabled
- Highs vs bass distortion protection: Fix window edges.
- Add highs distortion sensitivity slider(s)?
- DC caused by clipper
- Remove or simplify 'Advanced highs protection', look at other protection mechanisms.
- Fix pre-ringing artifacts
- Strict bass clipping
- Save new clipper options (STS+VST)
- Checkbox to combine bands 1+2 of Multiband
- Release 1 hour
- Add composite clipper
