Post new topic  Reply to topic  [ 424 posts ]  Go to page Previous 115 16 17 18 1943 Next
PostPosted: Thu Aug 04, 2016 8:14 am
I don't know, the person who reported this said that he updated to the latest version (which in its list of changes contained a lot of VST things) and that fixed the problem. So, if you update to the latest version it should be ok. (Beside that, I'm checking for it in my code as well so it won't cause a crash anymore).
after you wrote this information i take a look at the audacity homepage. and you are right. there is a hidden subpage where you can download nightly builds of audacity, like your beta versions.
http://gaclrecords.org.uk/win-nightly/
i tried the latest version, and it worked! thats really great. but unfortunately there is a maybe a new bug. the output waveform is not displayed. it's always black.
I think Hans refers to an email exchange I had with him. I was previously using Audacity v2.0.5, the issue I had was that Audacity was not compensating for latency when using Perfect Declipper; I had to manually append <latency> samples to the end of the file, then declip, then remove <latency> samples from the start of the file. The current released version of Audacity (2.1.2) fixed this. I was using the stand-alone declipper, and haven't tried Stereotool yet. This makes me curious to check it.
One thing I did discover: don't turn off the clipper GUI! The result is that Audacity tries and fails to display hundreds of rows of sliders, mostly unmarked, but a few with cryptic character strings Hans might be able to identify as variables...
Best regards,
Mike
PostPosted: Thu Aug 04, 2016 10:47 am
This was about the crash in older Audition versions when there are more than 4096 sliders, which appears to be fixed in the latest version.
For some reason, the VST spec only allows 8 character descriptions. Which works fine if you have names like 'Volume', 'Pitch' etc. But not if you have 2 multiband compressors with 9 bands each (Mb1B9Att would be Multiband 1 Band 9 Attack). There are more than 4100 sliders now. So, indeed, don't use that.
PostPosted: Thu Aug 04, 2016 11:18 am
Pre-emphasized not visible in output levels beta 018 and 019
PostPosted: Thu Aug 04, 2016 12:44 pm
whats the difference between Difference and Hear ??? ie i checked HEAR at Natutarl Dynamics and sounds VERY strange...
PostPosted: Thu Aug 04, 2016 12:55 pm
As i understand , difference was only the current module "work" .
But the "Hear" , will be the processing all before the current module including the current module.All ahead will be "muted"
PostPosted: Thu Aug 04, 2016 5:46 pm
Best regards,
Mike
hi mike,
thats great that you are being working on the audacity bug. but there is another strange bug, together with stereotool. i posted it some pages before.
The last beta does not work with the vst plugin in audacity on windows. you can open the plugin itself, but if you want to play something the whole application crashs without any exception.
in the last beta you publish i can process some audio, but only the first time correctly. you can only hear changes on the UI, if you do the following:
start audacity, Open a music file, open stereotool, load you preset an change anything. now you can directly hear what you change. if the music file ends and you play it again, then the sound is like the last change in the plugin. if you change anything nothing seems to be happen on the output. in the UI you can see the changes (for example the diffence in the wave form). this also occurs to other sound files. it only works the first time you open audacity and play the first music in live mode. other VST plugins does not have this problem in audacity.
it would be great if you correct this too. it seams to be very interesting.
PostPosted: Thu Aug 04, 2016 8:43 pm
That makes sense. When I (painfully) scrolled to the end of the displayed sliders, the last one appeared to display multiple lines of text in rapid succession, too fast to read. I was looking for something to enable GUI again. I finally took the brute force method of deleting pluginregistry.cfg, plugins.cfg, and pluginsettings.cfg from C:\Users\...\AppData\Roaming\Audacity (after copying elsewhere of course.) The software then regenerated those files. I also deleted PerfectDeclipper.xml, which did not regenerate, but seems not essential because the GUI was restored and PD is working.
This is in the current release version of Audacity, 2.1.2.
PostPosted: Thu Aug 04, 2016 10:54 pm
@Mike27: The setting to enable the GUI again isn't even in that list! That's a setting of Audacity, not of Stereo Tool :)
PostPosted: Thu Aug 04, 2016 10:56 pm
Fixed:
Windows stand alone: http://www.stereotool.com/download/ster ... 01-020.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 01-020.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 01-020.dll
Known issues:
- Add Declipper main view
- Paul Kriegler send gui
- Make new separate Presets class
- Check that FM output can still be L/R stereo if Stereo/RDS encoders are disabled
- Absolute Highs display broken. Only in HQ version. -> Weird only on Koek pc. Check tomorrow. Ah, only weird if there's real audio, not on background noise there. Maybe stereo effect? Still unable to reproduce on my pc...
- Add agc drive
- Thimeo.js DISABLED display
- Generate UIDs and use link
- Password for login?
DONE:
- Gain works again
- Type IP in web site
Later:
- Run as a service
- Websockets? Later
PostPosted: Thu Aug 04, 2016 10:57 pm
Shouldn't that be beta 20?
Fixed:
Known issues:
DONE:
- Gain works again
Later:
- Run as a service
- Websockets? Later
