@Hans I have a "special" request.! Is it possible to rename the main .exe file on installation?
The problem is when someone, like me, is running 2 ST from the same pc, one WEB and one Radio, so when i need to update there is a confusion on settings.
So, if it is possible to give or change the filename on istallation.
Thanks!
You can rename it afterwards.. Or even just copy the .exe to a different file name.
I have never seen an installer that lets you rename the executable file name...
You might think that in the installer, ask how many instances you want to install (BBP style). A minimum of 1 and a maximum of 4, say,
Default install one instance.
The first instance is, for example, "stereotool.exe", the second "stereotool_2.exe" the third "stereotool_3.exe" and the fourth "stereotool_4.exe", in combination with a ini file that is for each .exe
