Post new topic  Reply to topic  [ 218 posts ]  Go to page Previous 115 16 17 18 1922 Next
PostPosted: Thu Feb 27, 2020 1:48 am
Posted BETA040. Main difference is that the AGC now has a new "tighter" mode (that starts releasing slower) and a release hold. Purpose: In some tracks, mainly in parts with drums and not much else with a lot of (near) silence in between, these drums tend to come out too loud. These new settings can be used to fix that.
PostPosted: Thu Feb 27, 2020 6:17 pm
nice AGC improvements 8-)
however, enabling "tight mode" with "release hold" off, appears to have no effect.
(i still prefer the legacy AGC overall)
PostPosted: Thu Feb 27, 2020 7:11 pm
When trying to use the webinterface i get a white page with the following text: This port does not run Omnia SST or MicroMPX!
Kind regards,
Arkadas
I bet you anything the web interface is still being worked on. I just tried with beta 040 and no luck. Beta 032 works fine however if you still need the Web Interface, as I said earlier in this thread.
PostPosted: Sun Mar 01, 2020 4:15 pm
Hello ;)
For the French-speaking community, I propose you the translation of the software as is (.stl file in C:\Program Files\Stereo Tool).
viewtopic.php?f=23&t=27857
PostPosted: Sun Mar 01, 2020 9:32 pm
Hello ;)
Current version: 9.38 beta 040
French (Français) (Alain DELOBEL).stl
Excellent! I'm sure many will appreciate this. However perhaps you could post it in this subforum viewforum.php?f=23 where it can be easily found with the rest of the translations.
PostPosted: Sun Mar 01, 2020 10:39 pm
Hello ;)
@MrKlorox, Thank you very much, if you have any remarks to make about mistranslated terms or phrases, don't hesitate.
I moved the file to the appropriate location.
PostPosted: Mon Mar 02, 2020 5:34 pm
Seems like Hans won't take any attention to my request. All i wanted was a simple bass clipper instead of that limiter that makes bass muddy. the old releases of stereo tool (7.xx) had better bass.
Need Help? Call me, I can help you have a better sound with your actual audio processor, Analog? Unknown Brand? No Problem At All!
PostPosted: Mon Mar 02, 2020 6:21 pm
There is no bass limiter. There was a bug in one of the bass clipper stages that I've fixed I think 2 beta's ago (it was clipping at too high frequencies and too low levels). Which should give you much better bass now.
PostPosted: Mon Mar 02, 2020 8:31 pm
Enable deprecated settings, then take a look at the "Bass protection" feature under the bass section of the Advanced Clipper. YMMV, but it might accomplish want you want.
PostPosted: Tue Mar 03, 2020 1:39 am
that legacy bass protection feature is actually pretty good at 40Hz and lower.
bass-boosting at the end of the processing chain eliminates 'pumping' that would occur if the content is bass-boosted before/after AGC.
