Post new topic  Reply to topic  [ 2125 posts ]  Go to page Previous 1158 159 160 161 162213 Next
PostPosted: Tue Aug 30, 2011 11:59 pm
@ Hans
There is nothing can be done to fix this pre-ring sound caused by bass vs HPF vs loudness vs etc ?
Do you hear any pre-ringing if you don't use Loudness?
What happens if you turn Improved Loudness Distortion Protection and Very deep bass distortion protection off?
PostPosted: Wed Aug 31, 2011 12:51 am
Yes. But less (actually gone) if 1-band AGC. Or MB is OFF or HPF is OFF. - Like all filters do not like HPF. In other hand only HPF alone does not make this.
With higher Loudness settings and with HPF OFF, that sound is present but much less! So, HPF is maybe not problem at all, and that's why i ask you to move Phase-Linear HPF before AGC...
I was afraid that new steeper phase-linear HPF will make this sound more audible, but not, it's exactly same.
Both are not makeing this. just loudness.
PostPosted: Wed Aug 31, 2011 12:57 am
BETA107:
- Fixed edge vibrations in high frequency sounds when bass distortion protection kicks in (probably not noticeable).
- Added slider to control amount of allowed distortion in highs (more = louder highs).
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-107.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-107.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-107.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-107.dll
Command line version: http://www.stereotool.com/download/ster ... 20-107.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-107 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-107 NOT AVAILABLE
- Fix Punch
- Fix crash at program close
- Reduce Loudness CPU load
- Scopes black background?
- Add AGC start level
- Save bandpass filter order
- Fix Loudness display
- Smarter lows volume drop against highs protection: First clip using reduced highs (highs protection filter), then do it again but do NOT lower the lows below the level found in the 1st step. - NO! No longer needed.
- Optimize clipper code: Reflection, smaller overlap (stronger reflection possible?); optimize RMS search filter; optimize voice vibration removal
- HPF bad since BETA080, especially with declipper enabled
- Highs vs bass distortion protection: Fix window edges.
- Add highs distortion sensitivity slider(s)?
- DC caused by clipper
- Remove or simplify 'Advanced highs protection', look at other protection mechanisms.
- Fix pre-ringing artifacts
- Strict bass clip.
- Save new clipper options (STS+VST)
- Checkbox to combine bands 1+2 of Multiband
- Release 1 hour
- Add composite clipper
PostPosted: Wed Aug 31, 2011 2:19 am
Interestingly, it looks like DJ_DOGGY's issue is coming from the filter that protects against pre-ringing. And the filter doesn't work well enough. To be continued...
PostPosted: Wed Aug 31, 2011 4:10 am
I have VAC with option Cable format ... not cable range which means that if 176400 came then 176400 is switched ... when 96000 came then 96000 switched.
Also when it sounds like this i look into panell for Uflows or Oflows.. No does not go up when do like this.
There shouldn't be any buffer over/unders because Windows is doing SRC. That will tell you nothing.
What you need to do is match the Stereo Tool output rate in MpxTool, so they are both the same. If you're still getting aliasing distortion due to SRC, then you might have some other software on your computer that's opening the soundcard at a higher sample rate, causing this.
PostPosted: Wed Aug 31, 2011 8:23 am
Jesse .. Like I said I understand You ..and i`m sure that Windows is not the perfect system ...
But I test this issue with NO VAC .. Just WInamp/Foobar and DSP/VST plugins ... No difference . Same thing .
Did You test with the song of WU-TANG and method of "play only bass" that i post some pages ago. Like it seems Hans hear what I told ... so problem is not in my television :)
PostPosted: Wed Aug 31, 2011 9:10 am
BETA108:
- Tightened the pre-ringing filter. Note: This COULD cause other artifacts.
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-108.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-108.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-108.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-108.dll
Command line version: http://www.stereotool.com/download/ster ... 20-108.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-108 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-108 NOT AVAILABLE
- Fix Punch
- Release 1 hour
PostPosted: Wed Aug 31, 2011 9:13 am
Now I'm not sure anymore that what I hear and what you hear are the same thing. What I hear has _nothing_ to do with aliasing. I just hear some weird 'pops' in the bass. And if I turn ALL the filters off it's gone, it occurs when I turn any of a bunch of filters on (even if it does nothing). That's why I now suspect the pre-ringing filter which is switched on if any of those filters is used.
In your case, what happens when you enable BYPASS? That completely bypasses ANY processing, including up/downsampling etc.. If you still hear something then, it's definitely not the same thing that I'm hearing.
PostPosted: Wed Aug 31, 2011 10:13 am
When i hit bypass button everything is stopping .....
but when pressed pops in the bass are gone .
All options(filters) are disabled but still hear it ...
except any that isn`t visible for US only you know that they are working in background even with everything disabled .
So yeah this is the thing that i`m hear ( pops in the bass .. like blop blop .. blop ) . With the song of WU-tang You must clearly hear it if you enable only boost with "play only bass" . But it isn`t caused by this option - tested . Use only to cut only bass to play , perfectly for the test
PostPosted: Wed Aug 31, 2011 12:14 pm
Pre-Ring is DOWN! :D
