Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 345 posts ]  Go to page Previous 114 15 16 17 1835 Next
PostPosted: Fri Jul 24, 2015 2:41 am
Stereo Tool 7.71 BETA013
Windows stand alone: http://www.stereotool.com/download/ster ... 71-013.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 71-013.exe
Windows 32 bit VST: http://www.stereotool.com/download/vst_ ... 71-013.dll
Issues reported by DJ_DOGGY should now all be solved. Note: Junk around tones is still there if you enable Sparkling Highs without Protect Tones enabled. But that's intentional. Enable Protect Tones to get rid of it.
- Attempt to reduce effect on volume of using Leif's clipping method.
- Fix DJ Doggy's reported errors (19 kHz, junk around tones).
- Ignore frequencies above a specific frequency -> Should lower TOTAL CPU load by another 10-20% (now fully implemented except at lower Quality settings)
- Fixed the lowpass bug that was introduced in 009. Although it has probably always been there! As a side effect, the output is also slightly louder (about 0.02 dB) with no negative effects.
- Fixed distortion introduced in 009/010. Extra highs are still there though! See new 'Sparkling highs' section under Advanced Clipper -> Sound
- Fix optimizations
- Fix code #warnings
- Some small optimizations
TODO 7.71:
- Fix downsampling and Quality slider problems: Lower Quality setting
- Optimize Chain function: Move stuff to ProcessingChain if possible.
- Remove "Take some shortcuts" under CPU, probably broken! And has not much effect anyway. -> Hm, no, must have been in use for the tests. Ugh... TEST to check what is better: ON (which will probably allow more sounds through) or OFF.
- Synchronization is broken in 008 (was ok in 007)
- VST multiple instances fails
- Make VST window bigger
- Clipper highs improvement
- Noise learning Micha
- EQ with 'standard' sliders.
TO DO WITH LEIF:
PostPosted: Fri Jul 24, 2015 2:52 am
Meters frozen.
PostPosted: Fri Jul 24, 2015 3:18 am
Same here. Scopes work. No meters.
PostPosted: Fri Jul 24, 2015 7:20 am
Same here with the meters.
But same as before for the "Ignore freqs" issue. Unwanted signal that appears in bottom is still there.
PostPosted: Fri Jul 24, 2015 12:15 pm
Rebuilding now for meters. I will try to reproduce that 'Ignore freqs' issue again - I have seen it in the past but yesterday when I was testing I didn't see it anymore. Not sure why... At what frequency did you set it here?
PostPosted: Fri Jul 24, 2015 12:19 pm
I don`t know. May be when you test , forgot to apply any signal ? Because without signal , this issue is not there.
Just saying , This is the only way not to see it .
Edit : I set it to the lowest possible - 16000 . And this bad signal is exactly on 16000 Hz
If you set it 18000 , it will be at 18000 but with lower amplitude.
PostPosted: Fri Jul 24, 2015 1:35 pm
Stereo Tool 7.71 BETA014
Windows stand alone: http://www.stereotool.com/download/ster ... 71-014.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 71-014.exe
Windows 32 bit VST: http://www.stereotool.com/download/vst_ ... 71-014.dll
Meters working again.
- Fix optimizations
TODO 7.71:
TO DO WITH LEIF:
PostPosted: Fri Jul 24, 2015 1:39 pm
Ok I managed to reproduce it again now. Apparently it also disappears if you set the lowpass filter far away from this freq (which I did yesterday when I tested it to make sure that I would see it).
Edit: Whoops! There was a bug in my lowpass-filter code (which has been there forever, but normally the peak would be at 22.050 or 24 kHz and far less big). I've fixed it and the spike is reduced by 22 dB now, there's still something there though so there must be another bug somewhere.
Edit: I can't get rid of it completely it seems, but you shouldn't be using frequencies this close to the maximum used frequency anyway (ignore above 16 kHz with 15.5 kHz audio), so in normal use it should never be a problem.
PostPosted: Fri Jul 24, 2015 2:10 pm
Great !
I guess the rest of problem is in the "Ignore freqs" code .
PostPosted: Fri Jul 24, 2015 2:59 pm
Doggy, what signal you put on input?
