Nobody with issues anymore with this version? Such as partially drawn windows etc? If not I'll run some final tests and release it tonight.
I have some issues to report.
The declipper (VST version) window is drawn too large in foobar2000. That doesn't happen with other VST plug-ins or StereoTool.
File comment: Declipper window drawn too large in foobar2000.
The option "Clip output" works odd. When this option is turned off, clipping actually occurs. But when it's turned on, clipping never occurs. So it works exactly the opposite way. Also, when checking the option, reloading the plug-in with its previous settings always results in the option being checked (also with the opposite effect of preventing clipping).
In Adobe Audition 4 (CS5.5) I notice severe crackling in the output. This can be solved by checking "Bypass all" or unchecking "ON" in the declipper settings. CPU usage is low, so it's not a problem of the system being too slow (AMD Phenom II X4).
I also noticed some minor UI discrepancies. When trying to set the option "Quality / Precision" to the maximum value (5.0), the slider always shows 4.9 afterwards. But when settings are restored it correctly shows 5.0. The opposite happens with the option "Maximum restored peak level". When setting it to the minimum value (1.0), after reopening the window the slider is not placed fully to the left. The previously set value (1.0) is shown correctly, though.
