Post new topic  Reply to topic  [ 156 posts ]  Go to page Previous 112 13 14 15 16
PostPosted: Fri Apr 05, 2024 9:48 pm
Now that RDS2 support is added, does that mean the external RDS input will pass through the extra carriers? So I can do away with the ALSA dmix workaround.
NKUB-FM 100.7 The Cube
We're the station for LA's cubers!
PostPosted: Fri Apr 05, 2024 11:56 pm
Posted 10.31 BETA001, here: viewtopic.php?f=14&t=34069&p=76061#p76061
This new beta is basically the same as the 10.30 release which is building now, but with the new PortAudio version, new IceCast streaming version, and some waveform display fixes.
If you find any bugs, please let me know - they will likely also be in 10.30.
PostPosted: Fri Apr 05, 2024 11:59 pm
No, for now I only added encoding, no passthrough.
PostPosted: Mon Apr 08, 2024 1:13 pm
The Icecast streaming option sounds interesting, would that allow me to configure ST to send audio to Icecast? At the moment I use Liquidsoap to encode an AAC stream at 48khz 320K, so if I can use ST to do that then that's one less process to run.
Thanks
PostPosted: Mon Apr 08, 2024 1:17 pm
AFAIK, Icecast streaming has been there since I started using the software 6 or so years ago. At least this is a Windows option. I assumed it would be a Linux option as well; which is what you use if I'm not mistaken, correct?
PostPosted: Sun Apr 14, 2024 12:12 am
Thank you. Yes, you are correct. I run ST on a Raspberry Pi which is running Linux.
