Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 155 posts ]  Go to page Previous 112 13 14 15 16
PostPosted: Wed Oct 03, 2018 7:59 pm
ok i can see the assymetry there but what do you have in input???do you have a signal like sawtoth or music???
me i have all settings as you now i mean as in photo so i can see clearly the low pass is 4500hz but the bandpass filter is 30-18500hz is that right???my opinion is to has the same numero as low 4500hz
PostPosted: Wed Oct 03, 2018 10:54 pm
Music. It might be symmetrical for certain tones if an asymmetrical waveform would sound worse. So it's better to test with music than with test tones.
The bandpass filter is for the streaming output - the AM output itself is filtered at 4500, if you also enable streaming, the stream is lowpassed at 18500 in this case. You can change that under Processing -> Bandpass.
PostPosted: Thu Oct 04, 2018 3:22 pm
ok Hans
thanks for the info i,m doing all these from last night it goes ok,,,the assymetry is working much better in low frequencies than midle and high ...i think it has to do this with the samples...it needs more samples in high frequencies ...any way it works at least and i,m using this in am mode but Hans you can add a high pass filter there in the same place where you have the lowpass filter so its not nesecary to activate the band pass which is for streaming
and again regards
PostPosted: Sat Oct 06, 2018 11:26 am
Stereo Tool 9.03 BETA033 - RELEASE CANDIDATE
Windows stand alone: https://www.stereotool.com/download/ste ... 03-033.exe
Winamp DSP: https://www.stereotool.com/download/dsp ... 03-033.exe
VST: http://www.stereotool.com/download/vst_ ... 03-033.dll
VST: https://www.stereotool.com/download/vst ... 03-033.dll
Latest MicroMPX:
Windows MicroMPX web based decoder: https://www.stereotool.com/download/Mic ... 03-033.exe
Windows MicroMPX web based encoder: https://www.stereotool.com/download/Mic ... 03-033.exe
Windows MicroMPX command line enc/dec: https://www.stereotool.com/download/Mic ... 03-033.exe
Windows libsndfile-1.dll (needed for MicroMPX decoder and command line version, place in same directory): MicroMPX command line enc/dec: https://www.stereotool.com/download/libsndfile-1.dll
  • Fixed declipper display bug in input (wrong samples were red) for > 1 threads.
  • Bug: MB clipper display hangs when clipper is disabled, should be reset
  • VST 30 euro version
  • Bojcha: Bass clipper asymmetry mode kills some normal symmetric bass -> Shouldn't be needed anymore anyway (clipper has been greatly improved since that option was added), turned it off by default.
  • Adjust Dutch Moose
  • MicroMPX encoder: Turn Rate limiter on by default. Find good default settings. (Set to 20 kbit/s).
  • Updated Bojcha's DynaRider preset
  • RDS: RT+ issue Jeroen (3s: makes RT+ go on and off)
  • RDS: UECP: Decoder was skipping short (4 bytes or less) commands at the end of a message.
  • Fix showing license valid date in MicroMPX and SST - showed 1924 instead of unlimited.
  • Kantar: Input level was wrong, causing audible artifacts.
  • Difference reported between 8.54 vs 9.02 -> Tested, not there.
  • Make sure BIMP works
  • Fixed possible crash in Dehummer continuous learning mode
  • Decreased Dehummer continuous learning mode minimum time from 1 second to 0.1 second. Helps with reverb.
  • Made VST parameter names unique (except parameter eq's, they still need to be done)
  • Made UECP PSN, DSN etc. display in hex instead of decimal in GUI.
  • MicroMPX encoder now also added to DSP and VST plugins!
  • GUI crash or bad display in logged out mode when restarting after closing logged in in a specific submenu fixed.
  • Fixed GUI crash in plugins when going to I/O submenu (which is now merged with the main Config menu again).
  • Fix GUI crash in 915x577 screen size on non-4K screens.
  • Put something on I/O page (it's empty now)
  • Put Dutch Moose and PFD presets in SST
  • Add Kantar support
  • Added PFD preset (literally dozens of people requested that). Still need to change the name, it's the 2nd Dutch Moose in the list (the name is too long, so I'll rename it to just PFD 2018)
  • Add MicroMPX decoder abonneer-IP
  • Fri: SST/uMPX interface
  • The BIMP on LQLL
  • Bug fix: Dehummer had a crackle since version 014. That's back to normal again now.
  • Test MicroMPX with Stokkemask - 0.5 dB -> Changing setting in Stereo Tool helps
  • Show a warning if Quality it not set to 150% for Latency 128 and 256.
  • Bass Clipper sounds horrible at 128, True Bass at 128 and 256 -> disabled.
  • Update Dutch Moose
  • Clipper: Bass section lowpass freqs should not be too close at latency 512, 256, 128. (Noticeable in Dutch Moose preset)
  • Check that The BIMP works, maybe add parametric eq
  • MicroMPX rate limiter
  • 192 kHz input is broken! Output is mono, something is going wrong
  • SST ID's
  • Crackle in 2nd PDF track -> Improved
  • Allow lower latency (6 ms, 9 ms)
  • Improve clipper sound 1-6 kHz area
  • License The BIMP
  • Updated Paul Thompson's and Bojcha's presets
  • Updated Dutch Moose preset (more highs. less deep bass, less stereo widening, sounds much cleaner)
  • Stok: Lower samplerates look less good (and that makes no sense test without LOWER) -> 44.1 is ok now (-0.01 dB), 40 kHz is clearly lower (-0.20 dB), still way better than before (it was more than -0.40 dB in 9.02).
  • Add MicroMPX plugin licensing [22]
  • Fix Pi build (Stokkemask NEON code)
  • Update LogInOut code
  • New Stokkemask mode now works well in all Strictness settings above 7 (below 7 it's not very strict)
  • Stok: Post filter caused NANs
  • Stok: Move start point to later stage? (TUESDAY)
  • Cleanup code for VST3 David
  • Turn BIMP *OFF*
  • DrawWave draws outside of screen in FM analyzer (TUESDAY) - apparently ok
  • Include MicroMPX - for real now [22]
  • Hide Matrix Stereo for now
  • Stok: Add post filter
  • Stok: Legacy CPU load back to that of 9.02
  • API: Audio signal VU meter, info about whether stream is good NOW.
  • Started with matrix-based stereo widener; not happy yet.
  • Stokkemask NAN and other exceptions solved. (from previous beta)
  • Stokkemask threading issue solved. (from previous beta)
  • Stok: Remove overlap shortcut for stricter result (increases CPU).
  • Stok: Measure mask in every stage for stricter result (increases CPU).
  • Stok: Apply measured results in every stage for stricter result (increases CPU).
  • Stok: Replace L-R reduction in final stages by total volume reduction.
  • Stok: Figure out how to adjust shape at different sample rates -> Found correct Gaussian window sigma value instead, applied for both processing and display (which were set differently before!)
  • Stok: Replace "Looseness (sounds better)" by something that moves the mask up and down.
  • Stok: 1e stage only inner
  • Stok: More steps at end, needs to be both tighter and have less effect (is that last thing still needed???)
  • Stok: Try reducing the audio level in the final stage - lowering highs has proven useless at that point. --> SEEMS TO WORK, but only do this as the last stage!
  • MicroMPX SWEEP
  • Fixed a crash in the "Limit instead" code (Advanced Clipper).
  • Removed (moved to Extreme Tweaker for possible future testing) some Stokkemask settings that had a bad effect on compliance. Good settings are 50% / 30% / 40 dB (without the 40 dB it should be fne too, but there's a bigger chance at overshoots at the bottom of the mask. 100% for the first value increases overshoots!!!!! 39 and 38 should be safe as well - but I haven't had time to measure those separately anymore. Anyway in the older versions this value was set to 0....... Setting it higher may cause an audio quality reduction.
  • Crash fixed
  • Stokkemask: Try I/Q Clipper mode, highs are coming out slightly too loud, due to LPF? Might be good enough... -> Idea doesn't work
  • Stokkemask: We don't care about CPU load, try adding more stages -> No effect
  • Stokkemask: Default back to 50% for safety - that way we don't have to worry about breaking older versions. And we still get 90% of the improvement that way.
  • More experimental stokkemask settings added.
  • Stokkemask: Improved further (looks about equally strict, but I can squeeze over 1 dB more anti-phase content through than with 9.02). NOTE: SETTINGS ARE DEFAULTING TO 9.02 BEHAVIOR BECAUSE I DON'T KNOW YET IF THE SIGNAL IS EQUALLY STRICT, AND I DON'T WANT SOMEONE TO GET FINED FOR HAVING STOKKEMASK OVERSHOOTS. To get the new behavior, set "New looseness 1" higher (50% should definitely be safe, I'm not sure about 100%), "New looseness 2" to 30%, and "Side level" to 40.
  • Improved Stokkemask - output is stricter (closer to the mask), so it has less impact on stereo separation. (*)
  • Memory usage reduced by about 12 MB
    PLANNED:
  • Verify correct BS412 levels for Dutch Moose and Dynarider
  • Make installers for MicroMPX on Windows
  • Release
  • Backup audio doesn't go to LQLL
  • VST for DJB
  • Test Kantar -> FAILED.
  • Hiccups in display
  • AF method B
  • RDS AF method B, longer lists
  • Release
  • Test sound card DONE - now what?
  • Linux multiple instances
  • Fake stereo idea
  • RDS urgent issue
  • Cntrct IN
  • Test preset that causes buffer to run empty - why? --> Settings issue, maybe add a popup for this situation (buffer is slowly filling up or running empty)...
  • RDS: Support for AF method B
  • RDS: RT end at \n
  • Brian, NAB
  • MOBO
  • uMPX decoder: Add multicast subscribe
New vs old Stokkemask measurement numbers, relative to 48 kHz no stokkemask, for audio with quite extreme stereo. Numbers are L-R loudness, L loudness
Freq     old/new          L-R    L
48   kHz no  Stokkemask:  0.00,  0.00 (reference)
48   kHz new Stokkemask: -0.62, -0.27 (0.46, 0.10 better than old!)
44.1 kHz new Stokkemask: -0.63, -0.22 (0.54, 0.11 better than old!)
40   kHz new Stokkemask: -0.82, -0.29 (0.65, 0.14 better than old!)
48   kHz old Stokkemask: -1.08, -0.37
44.1 kHz old Stokkemask: -1.17, -0.33
40   kHz old Stokkemask: -1.47, -0.43
PostPosted: Mon Oct 08, 2018 6:35 pm
Version 9.10 is released! See viewtopic.php?f=14&t=25541
Remaining todo items:
  • Some streaming settings were only visible in Expert mode - should be always.
  • Linux .so build without X11 dependencies.
  • Linux bug fix: 32 bit R128 code crashes
  • Trip waveform jumps (see video)
  • VLC restarts all the time if watchdog is enabled - turning it off fixes it. -> if (r > 0) replaced by if (r == 0), should solve it.
  • 32 bit VST doesn't appear to work under XP (8.54 was ok).
  • Fix crackle in Wasapi on some Realtek pc's in MicroMPX - Was a driver issue, block size can be restored to 4096.
  • BriOm
  • Linux .so build error.
  • Increase resampling margins MicroMPX.
  • Proppfrexx integration error since 9.00: Also on Windows 10 (until now only reported on Windows Server), test...
  • WatchCat Windows 4K fonts, menu etc
  • Can we build WatchCat with /MT?
  • Fix warnings
  • Check clipper sound (probably ok)
  • Linux-version MicroMPX integration in ST.
  • Support for more than 32 ASIO channels
  • Automate generating MicroMPX licenses
  • Automate generating The BIMP licenses
  • Finish Kantar tests and integration
  • Brian, NAB
  • VST for DJB
  • Test sound card
  • Fake stereo idea
  • Cntrct IN
  • Add a popup for buffer overrun/underrun (also for suspicion)
  • Test ProppFrexx Windows 2012 server issue-
  • RDS: RT end at \n
  • Idioot coi idee
