Post new topic  Reply to topic  [ 155 posts ]  Go to page Previous 112 13 14 15 16
PostPosted: Thu Jan 04, 2018 12:36 am
Ow! What made you try that install? Are you sure that it never worked without (reproducibly) and always works with?
PostPosted: Fri Jan 19, 2018 9:12 pm
We have really a lot of nodes available for testing overhere, I have that one intact, I will test this for you once again in more detail but I am positive when I install these three (gnome-core xorg gdm3) on top of the mate desktop the latest two versions work.
I had already planned to test which one makes the difference by removing them and test it one by one after which I plan to install in live and upgrade to auto eq when bass eq comes available. I will let you know.
Since you read this, when I ship you an Orange PI PC2 (that will take about 14 days because I have to order it in China) is it possible to have a ST image for this singleboard available in the Raspberry section. If so set me the shipping address in the mail. It uses the Allwinner H5 processor therefore it is not compatible to your RPI 3 version but pricing is much much better and it's faster.
https://maasstad.online/
PostPosted: Fri Jan 19, 2018 9:31 pm
I just looked up the H5 and it's a Cortex A53. The 64 bit Pi version was built for that (the Pi 3 has a Cortex A53 as well - and yes it performs a lot better in 64 bit mode).
OW! I just noticed that I never put the 64 bit versions online!!!! Ugh.... But I do have them! I haven't really tested them either though. https://we.tl/o8P6M8gMzK . Let me know if it works!
PostPosted: Mon Jan 22, 2018 6:59 am
I will....
PostPosted: Mon Jan 22, 2018 7:46 am
I will....
Ok the alsa version works , jack version could not be tested because of a bus error in jack .... some stuff on the RPI forums on this, but that didn't help much
