Post new topic  Reply to topic  [ 209 posts ]  Go to page Previous 114 15 16 17 1821 Next
PostPosted: Tue Aug 22, 2017 9:52 pm
Hanz,
I made a small video to show you the difference between Beta 047 and 049.
http://www.upradio.be/2017-08-22_05-48-01.mp4
Sorry the recording of the videois in mono, but you hear the difference between 047 and 049
Look also the behaviour of the second Vu-Meter (Image Width Amplifier), it's different between the 2 versions.
Ok. so it *only* happens if you also enable Stereo Boost! And I did change some code there (completely forgot about that). So I know where to look now. It's a change that I made for SST, and apparently didn't test well enough.
PostPosted: Wed Aug 23, 2017 2:08 pm
Just advising that a update to the Aussie - Breakaway Dreams for 8.41 Beta049 is available in Share your Stereo Tool Settings.
PostPosted: Wed Aug 23, 2017 2:32 pm
--> Oops! I found it. Next beta should be ok again.
PostPosted: Wed Aug 23, 2017 2:33 pm
Sorry, I'm writing a translator. My idea is to add a second indicator that will show gain reduction bs 412, as is the case with other processors. This will make it much easier to adjust the limit bs 412 I will see this basic information on a normal g / r indicator instead of a complicated graph where at first glance it does not know what it shows.
Question: How do you use BS412 right now? The idea is to set it up such that it does nearly nothing but does get very very close to 0 dB (or +3, or whatever your local value is). But, the main point is the "doing nothing". So the lines in the current graph should not go more than at most about 2 dB down from the top. If that's the case, a live meter won't be very useful.
PostPosted: Wed Aug 23, 2017 4:13 pm
@Cleiton
[off topic]
The player comes from:
Presentation : https://youtu.be/XLHuEbxMTgs
DEMO : http://player.coolradio.be/demo
DOWNLOAD: http://player.coolradio.be
no need to add extra plugin or files to work with AAC+ :-)
PS: the stream on our player comes from a Tuner FM tuned on our Freq resample in AAC+ so we have the same sound as FM and we can monitor the transmitter ;-)
the stream to transmitter is mp3 320kbps
PostPosted: Wed Aug 23, 2017 8:42 pm
@Bojcha: the limiter is placed after the bass clipper. So if you enable limiting the bass is clipped, and then the whole signal is limited. That should be exactly what you were waiting for.....
By the way, the limiter also separately limits miss and highs. Not bass, bass is clipped.
Exactly, but it;s not good. What happens is that clipper clipp bass at, for example, 2dB then if i rise trhesh in limiter by 2dB, 2 bad things happens. First bass is back to 0dB and bass clipper instantly clip bass and then limiter is bit late to amplify it since it has some release.
So.. it need it;s own bass clipper, or it should follow settings from bass clipper in ABDP. I vote for 1st since it can be standalone.
Another thing, why it depends on "hard Limit"? about 0.8dB goes into hard limit after limiter. Cant measure because it kick well over 0dB after limiter without "Hard Limit"
btw, forum is working bad for months. many functions does not work, like make sticky forums.. etc.. Also this quoting..
PostPosted: Wed Aug 23, 2017 9:21 pm
The latest version of the forum software has issues. Unfortunately, going back isn't an option due to the large amount of spammers....
PostPosted: Wed Aug 23, 2017 9:27 pm
I'm very confused. There is no threshold so you can' change that. Or do you mean drive? But if you change that the bass clipping level doesn't move. I have no idea what you mean by "limiter is a bit late", and it never amplifies anything so I don't understand that either.......
It does use the settings from ABDP, including the settings that control distortion etc.
I can make it more strict if needed. But since hard limit is a limiter as well I figured it wouldn't make too much difference......?
PostPosted: Wed Aug 23, 2017 9:38 pm
8.41 BETA050.
Windows stand alone: https://www.stereotool.com/download/ste ... 41-050.exe
Winamp DSP: https://www.stereotool.com/download/dsp ... 41-050.exe
VST: https://www.stereotool.com/download/vst ... 41-050.dll
- SJP: Weird stuff at very low latencies with SJP levels, goes up and then down sometimes. -> 1 bug fixed, now remaining issue is level difference. THAT SHOULD NOT BE THERE though!
- Stereo Image was broken in BETA049
- Name "Spectrum Controller" -> Rename? DONE, now called Auto EQ
- FM Demodulator reported to be broken (must be the compiler switch again... grrr.... -> No, was caused by change in IPP!
- AM clipper is now always oversampled
- Allow moving equalizer between MB's
- Allow moving BB before last MB
- SST: Couple Hard Limit to clipper on/off
- SST: QoS dynamic DLL -> Werkt, maar QoS niet??
- SST: Network: Add "Interface" selection. Also priority?
- SST: Add Stereo Image phase filter - somewhere. Under AZIMUTH (rename it to Phase or something)
- SST: C-QUAM divide by 2 issue
- SST: Bass Boost: Relax limits on frequencies
- GUI doesn't work in some of the versions of 046
- Disable Pre Limiter display in limiting mode.
- Share PEQ, attack/release?
- Move Spectrum Control and new AGC out of "Experimental" tab, and allow licensing. --> Button to buy it will be added to the website on Monday!
- Show Spectrum Control and new AGC in bottom display
- Optimize limiter
- Allow using bass distortion in bass clipper when used for final limiter.
- Limiter display freeze
- Add pre-AGC classical music thing
- MicroMPX add display for packet reception todo add reset packets, fix timing, show current playing position
- Add "Advanced Dynamics" to license overview screen
- Finish pre-AGC classical music thing
- SST: Make list of new ID's
- 64 bit Hard Limit is working again
- Meter for Limiter is no longer frozen.
- 9sg - update to latest code
- Old web interface bug fixes
- 9sg 1 thread.
- Add bass clipper + final limiter for testing for streaming, to figure out once and for all if it's useful or not.
- Final limiter: Make speed depend on amount of bass clipping.
- Final limiter: Fix going though chunks.
- Spectrum Control: Abrupt Change Protection could overract because it ignored certain settings.
- Spectrum Control: ACP can overreact!
- Spectrum Control: Why is kick so fast?
- All compressors: Attack/release behavior in the new RMS mode was wrong, now fixed. Result is more consistent and movements are less sudden.
- Compressor inverse-Covfefe
- AM stereo downmixer 9
- Show backup input is active - change color of input level meters
- Final limiter: Put in separate file, so I can test it separately.
- Final limiter: Make own settings page. Lots of settings needed...
- Final limiter: Make it work for Quality != 100%, Latency != 4096
- MicroMPX web interface
- Fixed crash when changing number of bands in Spectrum Control.
- Add Parametric EQ to AGC 2
- RDS: 8 character words with <| go wrong
- RDS: Empty fields - remove?
New "Experimental" section, containing:
* NEW AGC
* New Spectrum Controller (replacement of Power Bass/Power Highs), adjusts the spectrum BEFORE the AGC, without affecting dynamics or loudness.
The Analog compressors now have new "Max ratio" and "Max ratio at" settings to have dynamic ratio's depending on how the amount of attenuation.
- Fix crash
- Check FB^2 ratio - Found fixed for NCME
- Make copy of Adjustment and only turn of if MAIN drops far enough. Should get rid of temporary rises (Abba)
- Fix "Shape" in new RMS mode (just square it?)
- Add Sudden Jump Protection (directly to compressor if possible)
- Fix Triple Normal Output separate processing clipping level if pre-emphasis for FM is disabled.
- SJP: Fix Attack speed (don't use weird Shape)
- SJP in SC mode broken in MULTICORE mode.
- AGC: Gate before Drive
- SJP: Compensate for window edge
- SJP: Remove dependence on latency setting (2048)
- SJP: Test at lower latencies: 4096, 2048, 1024, 512, 256, 128
- SJP: Better lookahead. NO. Good enough.
- AGC: Make lookahead depend on SJP on/off.
- Dynamic ratio: Weird behavior with 1.001:1 as start.
- ACP: Add On/Off in SC.
- SJP: Channel merging: Fix display
- Fix Max Ratio in GUI (break out in separate subpanel)
- SJP: Auto-calculate Level Boost
- SJP: Remove dynamic ratio and add asserts.
- SJP: Add support for ratio
- SJP: Auto-recover when close to target, so Level Boost is less critical -> Not needed I think?
- Test compressor behavior, compare with 8.40 and verify no changes
- Add licensing code (SC, Dynamic Ratio)
- SC ACP: Speeds should not affect it!
- Switched to a new compiler, slightly better performance (+3%)
- Improved NAN recovery handling and fixed 2 possible causes of NAN's
- Added maximum threshold to the compressor, it doesn't do anything if the input exceeds that level.
- Integrated MicroMPX in something.
- Send M.M. latest MicroMPX build.
- Screenshot/video Mathijs
- Old web interface avoid reload OR pass GUID. Right now top presets list is flashing.
- Old web interface: Original right load can be messy. Load left first? -> No load logo page first
- Old web interface: Fix left display
- Old web interface: Don't set default selection.
- Wide display: Make meter section wider
- Fix build warnings
- NAB! LW!
- ProppFrexx reported crash
- Reported sound card buffer overruns pthompson
- Linux version crashes in latest Debian (Jack compatibility issue?)
- MicroMPX web interface version: Make sure that all ranges are correct and everything is stable when changing settings. -> Mathijs & Matthijs
- SST: Update help
- SST: Rename Auto EQ
- SST: Ohio Valley and Blue Steel use Pre Amp
- Old web interface: Text color in check boxes and buttons doesn't update
- Old web interface: Fix display of vu meters, also for SC
- Add new presets!
- ladspa? r.co (Also AU & ProTools)
- Smarter stereo-to-mono conversion (only when needed). Use amount of reduction instead of maximum degrees!!!
- Optimize Spectrum Control and AGC 2
- Update RDS encoder to Mathijs' filter.
- ADYEN
- Growling bass (add to True Bass as post filter, compare with https://www.refusesoftware.com/lowender ).
- RDS: Make note in help about shared drives. Also send to Omnia.
- Try new stereo widener idea
- SST: Make it switch to backup input when the normal/FM signal switches.
- Make compressor with alternative ratio implementation
- Test clipping
- Improve UECP ASCII mode for Magic RDS (just handle \n's inside strings)
- RDS UCEP: Put a timeout on the fallback to default settings. Some programs close the connection immediately.
PostPosted: Wed Aug 23, 2017 9:49 pm
The file dsp_stereo_tool_installer_BETA841-050.exe still shows in Winamp as BETA049.
Is this just a version mistake?
