Post new topic  Reply to topic  [ 2125 posts ]  Go to page Previous 1147 148 149 150 151213 Next
PostPosted: Wed Aug 24, 2011 5:32 pm
BETA103:
- Separate clipping for low and very low frequencies.
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-103.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-103.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-103.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-103.dll
Command line version: http://www.stereotool.com/download/ster ... 20-103.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-103 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-103 NOT AVAILABLE
- Fix Punch
- Fix crash at program close
- Reduce Loudness CPU load
- Scopes black background?
- Add AGC start level
- Save bandpass filter order
- Fix Loudness display
- Smarter lows volume drop against highs protection: First clip using reduced highs (highs protection filter), then do it again but do NOT lower the lows below the level found in the 1st step. - NO! No longer needed.
- Optimize clipper code: Reflection, smaller overlap (stronger reflection possible?); optimize RMS search filter; optimize voice vibration removal
- Remove or simplify 'Advanced highs protection', look at other protection mechanisms.
- Save new clipper options (STS+VST)
- Checkbox to combine bands 1+2 of Multiband
- Release 1 hour
- Add composite clipper
PostPosted: Wed Aug 24, 2011 5:53 pm
Hmm, bass is even better then in b101. i skipped b102.
Still don't understand this new frequencie sliders... are they clipping at some lower level then 100% ... etc. .. (?)
PostPosted: Thu Aug 25, 2011 2:28 am
BETA104:
- Optimized clipper code. There were some steps in it that were quite expensive - one was even unpredictable. That's now solved.
- Fixed VST bass AGC parameter issue.
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-104.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-104.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-104.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-104.dll
Command line version: http://www.stereotool.com/download/ster ... 20-104.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-104 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-104 NOT AVAILABLE
- Fix Punch
- DC caused by clipper
- Add highs distortion sensitivity slider(s)?
- Release 1 hour
PostPosted: Thu Aug 25, 2011 2:31 am
The whole bass band (upto 700-1200 Hz) is clipped at 100%. Only the portion below 400-700 Hz of it is used.
The whole bass band is ALSO clipped at a lower clipping level. The portion below 150-300 Hz of that is used.
The mids band contains data above 150-400 Hz, and is clipped at 100%, but only the part above 400-700 Hz is used.
The highs band is clipped at 200% - I guess I should add a slider to control that.
Hope this is somewhat clear, I think an image is needed to really clarify this.
PostPosted: Thu Aug 25, 2011 2:53 am
PostPosted: Thu Aug 25, 2011 1:38 pm
I like BETA104...I haven't A/B compared this to BETA103 yet but it does sound better just from a quick listen.
Whatever you are doing Hans, you're doing it right.
PostPosted: Thu Aug 25, 2011 3:11 pm
beta104 is definately better than 100. Its not "oversensitive" anymore. The pump-effects in most tracks are nearly gone, found just 1 or 2 metallica tracks where i can still hear it, but they are really loud. Good job so far i think. :)
PostPosted: Thu Aug 25, 2011 9:17 pm
I have a very big peak in FM broadcasting with beta 104, in beta 79 it's ok
Preset Extreme
Up 75Khz to 100Khz !!
in french song "Mika - Elle me dit"
PostPosted: Thu Aug 25, 2011 9:44 pm
Preset Extreme
How do you measure it? What transmitter do you have. Have you calibrated tilt of soundcard?
PostPosted: Thu Aug 25, 2011 9:57 pm
With pira 75, i have a transmitter professional RVR
The test is beta 79 ok and after beta 104 peak...
With Lady gaga the edge of glory is up to 70 at 95 khz !
Pm is very loud ok at 8db, the beta 79 is lower louder
Fm overdrive is 100%, the at 120% the same result
preset Extreme europe 50us, the default parameters
