Post new topic  Reply to topic  [ 154 posts ]  Go to page Previous 112 13 14 15 16 Next
 Post subject: Re: Stereo Tool 7.41
PostPosted: Mon May 19, 2014 2:03 am
@near05:
This happens when you enable the DeLossifier. Fixed in this new build (I decided to run one more build before releasing, to fix this issue and to update a few presets).
@bob0r:
I have no idea how this could happen. Windows doesn't know anything about ST versions and there's no auto upgrade/downgrade in Stereo Tool either. Are you sure the old version was not installed in a different location and you're starting that one now?
New beta: BETA742-019 - RELEASE CANDIDATE 2.
Windows stand alone: http://www.stereotool.com/download/ster ... 42-019.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 42-019.exe
Windows VST 32: http://www.stereotool.com/download/vst_ ... 42-019.dll
Windows VST 64: http://www.stereotool.com/download/vst_ ... 42-019.dll
Linux 32 bit:
Linux command line: http://www.stereotool.com/download/ster ... ETA742-019
Linux GUI/Jack: http://www.stereotool.com/download/ster ... ETA742-019
Mac OS X:
Mac stand alone (Jack): http://www.stereotool.com/download/ster ... 42-019.zip
Mac VST 32 bit: http://www.stereotool.com/download/ster ... 19.vst.zip
Mac VST 64 bit: http://www.stereotool.com/download/ster ... 19.vst.zip
Mac command line: http://www.stereotool.com/download/ster ... ETA742-019
Changes:
- Add presets, waiting for Thorium6 update/web version, and need to set correct levels (generic presets, BS412)
- Change version number to 7.42
Old Changes:
- Maybe change band 2 band shape (feedback Bojcha) -> apparently not
- Optimize new MB flat (1 FFT instead of 9) - DONE
- Old Flatness slider must be disabled when 'Flat tops' is enabled; other checkbox right to 'Flat tops' might be removed again. - DONE
- Fix Perfect Declipper keyboard input so I can also release a new declipper version
- Check performance DONE, difference is less than 1%
- Added a lot of new presets.
- Fixed the compressor Knee bug in 015.
- Added the first few new presets, and removed a bunch of others
- Lots of small issues that might cause problems on different systems/plugin hosts etc. resolved: Rounding error in compressors.
- Added 'Flat tops' in Multiband Compressor and Natural Dynamics, with different band contents and improved crossover/flat output behavior.
- Added experimental DeLossifier (MP3 artifacts removal filter). So far it only reduces pre-ringing a bit.
- AM support doesn't work properly: viewtopic.php?f=2&t=5512&p=24635#p24635 FIXED
- Linux version crashed - FIXED
- Crash in 64 bit VST plugin in compressor - SHOULD BE FIXED NOW
- Hangup with Marian Windows 7 driver: WORKAROUND AVAILABLE
- Added Marian sound card driver hangup workaround
- Added locking to MM audio I/O code to protect buffers
- Declipper behavior at extremely low latencies (256 samples or less) improved
- AM Assymmetry in combination with FM pre-emphasis enabled again
- Deemphasized audio didn't work properly under all circumstances in 7.41, fixed again.
- Code improvement: Potential rounding error in compressor (which could lead to all kinds of issues) fixed
- Code improvement: Initializing some values that were never initialized before
- Code improvement: Several 'Division by 0' situations (which were masked so they didn't cause problems) are now completely removed
- Release
- Hangup with Marian Windows 7 driver: attempt to pinpoint the cause together with Marian.
- Dotted area in ASIO input buffer (GUI only) TO BE FIXED
If I get no complaints about this version I will release it tomorrow.
PostPosted: Mon May 19, 2014 4:05 am
When I have installed the past 2 betas they have wiped out my settings and registration number from the .ini file. I have had to load the preset again and add the license number back in.
Clipper
PostPosted: Mon May 19, 2014 9:52 am
Clipper
That doesn't happen here - which one are you talking about exactly? (DSP, VST, stand alone, Windows, Linux, Mac, 32 or 64 bit?)
PostPosted: Mon May 19, 2014 3:17 pm
The Windows Stand Alone version 32 bit.
I will try it again tomorrow and see if it repeats the behaviour.
Jim
PostPosted: Mon May 19, 2014 5:49 pm
@near05:
I've just tried the version 19. Strangely, thereby enters exactly the same effect as on the version 18 Here, too, I have again attached a picture. Am I doing this new feature, so it's absolutely fine. But somehow it seems to be true still not quite.
PostPosted: Mon May 19, 2014 7:30 pm
I'll have to check what I return as latency in the VST version. I did test the command line and DSP versions and there everything was fine; I'll check if my VST delay calculation is different.
PostPosted: Mon May 19, 2014 7:37 pm
@near05:
@bob0r:
Linux 32 bit:
Mac OS X:
Changes:
Old Changes:
- Release
Ah, how stupid of me: startup from 32bit dir.
PostPosted: Mon May 19, 2014 10:41 pm
@near05:
Confirmed: There were not 2 but 3 places where the audio delay was calculated. And I missed the one for VST files.
(Until now the calculation was just the delay setting in the GUI, but for the delossifier I need to add 2.5 MP3 blocks of 1152 samples each).
7.42 is already released now, but I will fix this in 7.43 (which I think will be available soon, probably within a few days). For now, keep the delossifier turned off if you don't want to have this shift.
