BETA101:
- Reduced amount of pre-ringing in clipper
- Improved bass kick a bit
What was wrong: I was taking the frequency range 0..150/250 Hz and clipping that, then adding it to the rest of the sound. Now that's ok, but I did this multiple times. And because each time I ignored the higher frequencies, for loud bass kicks the peak re-appear each time the high frequencies are removed and are hence dropped further.
I've now reduced the number of clipping steps from 7 to 2. This should help a lot (and it really sounds better).
I think I can improve things further, will try that soon.
Note: Filtering frequencies default values are changed from 150/250 to 250/400. This protects better against distortion, and also reduces the 'pumping' effect that Vortran described.
Winamp DSP plugin:
http://www.stereotool.com/download/dsp_ ... 20-101.exe
Stand alone version:
http://www.stereotool.com/download/ster ... 20-101.exe
VST version:
http://www.stereotool.com/download/vst_ ... 20-101.dll
VST version (No SSE2):
Command line version:
Linux command line version:
http://www.stereotool.com/download/ster ... ETA620-101 NOT AVAILABLE
Linux GUI version:
- Fix Punch
- Loudness: Annoying cracking sound in bass. Slightly present in 5.00, worse in 6.00, maybe even worse in 6.10. Only when bass is too loud. Much worse than in Final Limiter (at same input level!) - so this clearly indicates a bug. Most likely cause: The filter that was added to remove bass artifacts.......
- No, it's the louder bass. But it can be fixed by changing some settings. Default settings updated, and behavior for 'not Very strict' improved. Also Deep bass boost and Very deep bass protection are enabled for latency 512 now.
- Fix crash at program close
- Reduce Loudness CPU load
- Scopes black background?
- Add AGC start level
- Save bandpass filter order
- Finish blind interface WAITING FOR FEEDBACK TODO: TEST:
Only display this window when needed.
- RDS issue reported here:
viewtopic.php?f=15&t=3703&p=11524#p11524 partially solved
- Optimize clipper code:
Reflection, smaller overlap (stronger reflection possible?); optimize RMS search filter
- Fix Loudness display
- Remove or simplify 'Advanced highs protection', look at other protection mechanisms.
- Save new clipper options (STS+VST)
- Smarter lows volume drop against highs protection: First clip using reduced highs (highs protection filter), then do it again but do NOT lower the lows below the level found in the 1st step.
- Update presets? (BASS_AGC etc.)
1 day
- Change version number
1 hour
- Release
1 hour
- Add composite clipper
