Post new topic  Reply to topic  [ 424 posts ]  Go to page Previous 113 14 15 16 1743 Next
PostPosted: Sun Jul 31, 2016 1:14 pm
Hans, is the AGC gate visual completely vanished ?
Using here 801-016 beta dsp version.
This are now displayed the same as the gates in the compressors (at the bottom of the bars).
I dont see them anymore too.
Also "Hear" does not work as should.
PostPosted: Sun Jul 31, 2016 2:06 pm
I think this is very very very old problem
EDIT : i found "Input without processing" is broken . It empty the buffer and sound little fast ?!
Also i have about 2% CPU increase :) according to the red line
Which red line? Do you mean the red bar? And if so, compared to which version, 8.00?
Yes, it`s compared to 8.00 release. And yes- red bar "Percentage of processing", second row
May be some logging checks ? or something - i don`t know
PostPosted: Sun Jul 31, 2016 9:41 pm
One more....
I see that MB meters and Clip meter are responding with some delay (may be other meters too) ! From where is that delay?
On very down side scopes are OK .
PostPosted: Sun Jul 31, 2016 10:01 pm
There is nothing displayed at the bottom of the bars, even not when I change the gate from left to right. (DSP)
PostPosted: Sun Jul 31, 2016 11:23 pm
not sure of it's a bug, but using the built in sweeps aren't working ok in the last Beta's, crackled Sine and thootsaws. Even with a VAC cable @192 Khz.
The last time I used the sweeps, I was running v7.* stand alone.
PostPosted: Mon Aug 01, 2016 1:17 pm
That's indeed a bug which is caused by the redesign of the framework. Will add it to the todo list (it's missing).
PostPosted: Mon Aug 01, 2016 11:35 pm
Windows stand alone: http://www.stereotool.com/download/ster ... 01-017.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 01-017.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 01-017.dll
Known issues:
- Make 'Till here' work (wednesday)
- OS_COPYTHREADPRIOTO(td[ch].process_thread) (wednesday)
- Generate UIDs and use link
- Password for login?
- Quality between 100 and 150%?
DONE:
- Gain works again
- Type IP in web site
Later:
- Run as a service
PostPosted: Tue Aug 02, 2016 5:57 pm
TODO: Add exception if ignoring too high VST parameter numbers (Audacity bug! -> Was fixed in later Audacity version, never mind).
in which audacity version was this fixed?
PostPosted: Tue Aug 02, 2016 7:30 pm
Is the window missing in AGC?
PostPosted: Tue Aug 02, 2016 7:58 pm
Not implemented yet, I guess.
