I did, what Bojcha said:
6:11 track 192 kbps 44.1 mp3 stereo into 16 bit PCM 44.1 wav:
Loaded preset with default settings (Bojcha B-Town 4/Bojcha King's Fire - both FM), minutes:
ST1: 1:59/1:49
ST2: 1:46/1:41
ST3: 1:42/1:34
1 = Old/Old, 2 = Old/New, 3 = New/New
This is for i5 3210m (Instruction set: MMX, SSE1, 2, 3, 3s, 4.1, 4.2, AVX, AES, EM64T, VT-x) running Win7 Home Premium x64 SP1
I will update this shortly for other CPUs that I have
EDIT: Athlon II x4 620 (Instruction set: MMX, 3DNOW!, SSE1, 2, 3, 4a, AMD-V, x86-x64) running Win7 Pro x64 SP1
ST1: 3:20/3:03
ST2: 3:23/3:06
ST3: 3:13/2:59
EDIT: E2220 (Instruction set: MMX, SSE1, 2, 3, 3s EM64T) running Win7 Pro x64 SP1
ST1: 3:45/3:25
ST2: 3:44/3:20
ST3: 3:40/3:16
EDIT: i3-370m (Instruction set: MMX, SSE1, 2, 3, 3s, 4.1, 4.2, EM64T, VT-x) running Win7 Home Premium x64 SP1
ST1: 3:02/2:49
ST2: 2:59/2:50
ST3: 3:00/2:35
I got similar results (only slightly different) twice for this one, which points out, that preset might affect the readings.
I didn't test i3-3220T as it is basically the same chip as i5-3210m (dual core, hyperthreaded, has SSE4.1, 4.2, AVX, the only difference is that it doesn't have turbo and AES support).
