Post new topic  Reply to topic  [ 2125 posts ]  Go to page Previous 113 14 15 16 17213 Next
PostPosted: Fri Mar 18, 2011 10:32 pm
Hm, as you can see the lower order highpass filter is much closer to the phase linear filter. So that's what you ask for, right? (something in between: Less phase effect, but also less steep filtering).
Increasing the ripple (which is still very small, a few % now) increases the steepness without increasing phase effects. So that's good.
PostPosted: Fri Mar 18, 2011 10:39 pm
but Order "2" Does not work at all .. almost!
So again Phase linear better
PostPosted: Sat Mar 19, 2011 12:31 am
True. But the old implementation used order 9 - so ANY other setting should be better (in terms of phase changes etc.) than that.
PostPosted: Sat Mar 19, 2011 2:18 am
Would it help to know that most of the bass issues I was having were addressed by other changes in the betas? I don't really hear much of any difference with the new highpass vs. the old, but giving configurability to it should be a good thing, I would think...
Anyway, I haven't tried to analyze the signal, but what I was hearing, I don't hear anymore. Either you had improved something, or my hearing has gotten worse... ;)
PostPosted: Sat Mar 19, 2011 3:10 am
What's the point here is that i found some track are meking voice and other distortions at non-phase HPF, and some track are makeing disatortion in Phase-linear HPF.
What i was think is that something in the middle will make it good for most tracks.
Nooooo... That's not how it works.
Basically, the non-phase linear highpass filter introduces a phase shift (just like the 'Phase Rotation' filter). And that works better for some than for others.
I should add though that I did hear some weird effects at the border frequency in older versions which seems to be completely gone now, so I think the new version is (slightly) better. But this does not - or at least not in a reliable way - change the voice vibrations.
PostPosted: Sat Mar 19, 2011 3:14 am
BETA620-017:
No interesting changes. Just changed the version number to 6.20 and re-enabled the full screen mode in the DSP plugin version. This is the version I'll take to the Sound Processing Freak Day...
BOJCHA, you were talking about a new really different preset. If you have something good, even if it's not completely finished yet, please tell me now!
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-017.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-017.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-017.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-017.dll
Command line version: http://www.stereotool.com/download/ster ... 20-017.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-017 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-017 NOT AVAILABLE
- Fix Punch
- Update presets? (BASS_AGC etc.)
- Release 1 hour
PostPosted: Sat Mar 19, 2011 4:55 am
np, i'll upload it Later today..
and recheck with ProcessingFreakDay's processing test. :)
PostPosted: Sat Mar 19, 2011 1:16 pm
I skipped some beta's but i think the bass distortion is indeed much better now.
I don't see Stereo Tool in the schedule of the Soundprocessing Freakday, see you there, maybe.
PostPosted: Sat Mar 19, 2011 2:41 pm
Hans => the "gui " of the vst version (last versions 6.20 beta) doesn't run on my vst host , but run good with the 6.10 :shock:
edit; run good too with the vst_stereo_tool_BETA620-009.dll but not with the beta620-016 and beta-017
PostPosted: Sat Mar 19, 2011 2:50 pm
The gui window on the vst version does run on vsthost up to beta 6.20-011 . Versions 12 and up just display a blank white window.
J0HN II
