it still doing that.
BNow i am on totally different PC. WinXP sp3, AMD AM2 Dualcore..
Ow...
I've still never seen this happen... I might have an idea for a solution (assuming that it happens when the window is made visible again, I could disable the code that checks the window size when I restore the window).
Just to be sure: This happens when you click the tray icon to restore the window, right?
I'll disable the window size code at this point, that should have no bad effects and it might help.
(Bojcha: Which Windows style have you selected? Classic, WinXP, ...? Because I think that might also make a difference in the handling of borders etc.)
Whenever something happens to the window I check the window viewport size, and the border size, and I make sure that the window size is AT LEAST as big as viewport + border. My guess would be that the border size isn't always determined correctly when the window is restored.
edit: Loading preset from FILE keeps Latency mode .. only Loading preset from menu push it always to 4096. That's ok (?)
That's intentional. Loading a preset sets the latency belonging to that preset (for example, the 'watching a movie' preset sets a low latency). Loading a preset from file keeps the setting that you've selected. I think you might be right: Saving the latency as part of the preset might indeed be a good idea.
This is a bit odd:
- Latency: For latency it kinda makes sense to store it. Selecting a different preset also sets this.
- Quality: This is more risky. Is someone who has no experience with Stereo Tool loads a 3rd party preset, and the quality is lowered, every following preset might sound bad as well. And I don't think it's a good idea to reset the quality when RESET is pressed or a standard preset is selected.
So that means I would have to handle Latency and Quality differently, which might also be confusing.
Suggestions, anyone?
