Post new topic  Reply to topic  [ 292 posts ]  Go to page Previous 112 13 14 15 1630 Next
PostPosted: Wed Nov 13, 2013 11:26 am
Warning: When using compressors in Traditional Peak mode, this version has a much higher CPU load, because I've added some extra features for testing. If they are useful I'll optimize them.
Windows stand alone: http://www.stereotool.com/download/ster ... 32-015.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 32-015.exe
Windows VST: http://www.stereotool.com/download/vst_ ... 32-015.dll
- Optimized waveform display, scrolling is now much smoother and CPU load lower
- When you zoom in a lot, waveform is switched off
Coming in next version:
- CPU load for Traditional Peak optimized - now similar to before I made the new parameters configurable
- CPU load for moving mouse over Bands or Equalizer displays greatly reduced
- Compressor: Peak mode replaced by Traditional Peak, RMS by Traditional RMS; RMS compatiblity mode available for old presets (only thing it does is raise the thresholds by 1.75 dB). Code is further optimized.
PostPosted: Wed Nov 13, 2013 2:27 pm
Has anyone else compared RMS vs. Traditional RMS? I've done a few tests today and I think that - at least in multiband mode - I really prefer Traditional, because it handles sudden spikes much better and - except for that - is very similar.
The only problem is that the differences are very similar but still enough different to make it a bit difficult to completely remove the current RMS mode (which is what I want to do - I want to replace Peak and RMS by Traditional Peak and Traditional RMS, which are much simpler and require far less processing power).
Peak -> Traditional Peak seems fine, no changes to presets needed.
RMS -> Traditional RMS needs a bit of a volume boost, and it doesn't behave exactly the same. Now, if it's BETTER that's no problem... But I'm curious what other people hear.
PostPosted: Wed Nov 13, 2013 3:30 pm
Now when lower than 0.025 sec it switches off. Before it went lower.
PostPosted: Wed Nov 13, 2013 3:48 pm
Yes.. one step skipped.
PostPosted: Wed Nov 13, 2013 4:18 pm
O I forgot a 0. It should turn off below 0.0025, not 0.025. Fixed in next build.
PostPosted: Wed Nov 13, 2013 5:48 pm
Ok, if you found it better like that, then use that settings, but there is reason why are settings like that there.
If anything other than spec compliance could you please explain?
bob0r, why not try and share your settings ??
Bojcha - King's Fire 2 + Advanced Bass Distortion Protection settings back to default now. :-)
PostPosted: Thu Nov 14, 2013 11:03 am
Windows stand alone: http://www.stereotool.com/download/ster ... 32-016.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 32-016.exe
Windows VST: http://www.stereotool.com/download/vst_ ... 32-016.dll
I'm measuring a 13% performance improvement vs. version 7.31 for streaming presets. (That's how much data I can push through, and since the compressors work on 2 cores the effect on the CPU load must be even bigger). The effect on only the compressors and Natural Dynamics is over 30%.
PostPosted: Thu Nov 14, 2013 12:12 pm
Moving on bands and equalizer is load extra 15% of CPU power :)
I don`t know before what it was but now is 15% more . Is it normal ?
Or i don`t know why only on these areas the load is so much ? Any explanation of this ?
It looks like there is some lowering of CPU load at all , yeah
PostPosted: Thu Nov 14, 2013 1:40 pm
It redraws that section. Before, it would redraw the whole display so that was a lot more expensive that this!
PostPosted: Thu Nov 14, 2013 1:46 pm
Ok , understand now . Thank you
