Post new topic  Reply to topic  [ 2125 posts ]  Go to page Previous 1137 138 139 140 141213 Next
PostPosted: Sun Aug 21, 2011 5:50 pm
no, this is better then beta79. I tuned to be even better then your recording with my preset that track from PFD.
edit:
Comparing now with Omnia.9. Somehow that sound is with much less mids/mid-lows.. and more highs. I guess more highs because comoposite clipper and higher LPF. But this mid-lows are so low sometimes.
PostPosted: Sun Aug 21, 2011 5:58 pm
edit:
Ok, great! Then I'll leave it this way at least for now. (As said earlier, I just want to get a version out now, and it should be better than 6.10. For now I think that should suffice.) I guess the punch for highs is still an issue though?
About composite clipping: That will have an even bigger impact than before when I create it because the highs distortion will be less bad with composite clipping, so I also have to filter out less distortion. So yeah, I really need that! (But first I want to finally release version 6.20).
PostPosted: Sun Aug 21, 2011 6:05 pm
The beta 99 is better than 79
Good !
PostPosted: Sun Aug 21, 2011 6:12 pm
Please if you can re-enable freq.sliders...
edit: can this protection be faster ? (faster up and down speed)
PostPosted: Sun Aug 21, 2011 6:30 pm
No I don't think so. It's already as fast as it can be. The only things I could change are:
- Allowing (slightly?) more distortion
- Not removing distortion from very short highs. Or maybe not removing it at the start of the highs.
I guess no-one is using 'old style protections' (same as BETA089) anymore now? If not I'll remove that code again.
PostPosted: Sun Aug 21, 2011 6:36 pm
i foud what eat puch a bit...
Old problem with Phase-Linear HPF.
PostPosted: Sun Aug 21, 2011 6:54 pm
I see in todo list:
- Add composite clipper
Can't we expect this anymore for 6.20 then? Can you post new list with next beta.
PostPosted: Sun Aug 21, 2011 6:58 pm
No, but I'll make it immediately afterwards.
Will do so - these last few beta's were "not suitable for broadcasting" versions, actually more like an attempt to completely redesign the clipper, that's why I didn't include the whole thing.
PostPosted: Sun Aug 21, 2011 6:59 pm
You mean the rumbling sound? Could very well be... Well if it's that I can fix it.
(So far I've been testing with the clipper as stand-alone filter, so I just fed it the same input and ONLY clipped it. I guess I need to test it together with the rest as well.)
PostPosted: Sun Aug 21, 2011 8:21 pm
Yes.
It removes first few blocks of punched bass sounds, and replaces it with that rumble sound
