Post new topic  Reply to topic  [ 424 posts ]  Go to page Previous 112 13 14 15 1643 Next
PostPosted: Sat Jul 30, 2016 5:38 pm
It should be no beta 016? For this was the beta 015
Edit: strange output Pre-emphasized is off but on the meter it looks on.
PostPosted: Sat Jul 30, 2016 6:47 pm
I think this is very very very old problem
EDIT : i found "Input without processing" is broken . It empty the buffer and sound little fast ?!
Also i have about 2% CPU increase :) according to the red line
PostPosted: Sat Jul 30, 2016 8:15 pm
Edit: strange output Pre-emphasized is off but on the meter it looks on.[/quote]
Since the official 8.00 release I've been having the same pseudo pre-emphasized output, at least looks like that.
PostPosted: Sat Jul 30, 2016 9:17 pm
Daniel, you have to edit the link to get beta 016 !
dsp version: http://www.stereotool.com/download/dsp_ ... 01-016.exe
PostPosted: Sat Jul 30, 2016 9:26 pm
Yes, input gain works now in beta016
PostPosted: Sat Jul 30, 2016 10:08 pm
Hans, is the AGC gate visual completely vanished ?
Using here 801-016 beta dsp version.
PostPosted: Sun Jul 31, 2016 2:21 am
Whoops - posting this one again, now with correct links
- Gain works again
Windows stand alone: http://www.stereotool.com/download/ster ... 01-016.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 01-016.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 01-016.dll
Known issues:
- Reduce ProcessingChain memory usage (tomorrow)
- Display CPU usage for all threads and for LQLL threads (tomorrow)
- Set affinity for LQLL (tomorrow)
- Display updates must happen in correct order (weird noise jumps otherwise) (tuesday)
- Generate UIDs and use link
- Password for login?
- Quality between 100 and 150%?
- Don't calculate FM signal if FM is disabled (causes extra display in output too)
- Test tones are broken
DONE:
- Type IP in web site
Later:
- Service
- TODO: Add exception if ignoring too high VST parameter numbers (Audacity bug!).
PostPosted: Sun Jul 31, 2016 2:22 am
This are now displayed the same as the gates in the compressors (at the bottom of the bars).
Since the official 8.00 release I've been having the same pseudo pre-emphasized output, at least looks like that.[/quote]
That still needs to be fixed.
PostPosted: Sun Jul 31, 2016 2:24 am
Which red line? Do you mean the red bar? And if so, compared to which version, 8.00?
