Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 112 13 14 15 1659 Next
PostPosted: Thu Feb 04, 2016 5:03 pm
7.85 BETA023
Windows stand alone: http://www.stereotool.com/download/ster ... 85-023.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-023.exe
Windows VST 32 bit: ----://www.stereotool.com/download/vst_stereo_ ... 85-023.dll NOT YET AVAILABLE
CHANGED:
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Exciter: Improve further, and make it configurable.
- Add Polar stereo viewtopic.php?f=16&t=6233&p=33031#p33031
- MP3?
- O skin
PostPosted: Thu Feb 04, 2016 10:21 pm
Crashes of Tooltips are gone now, but strange: every time I close StereoTool normally (standalone 32-bit), I get this error message...
PostPosted: Thu Feb 04, 2016 11:52 pm
Hm, there was an issue with the DLL versions but not with the stand alone I think. I will run a rebuild now to check if that fixes it.
PostPosted: Fri Feb 05, 2016 12:51 am
7.85 BETA024
Windows stand alone: http://www.stereotool.com/download/ster ... 85-024.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-024.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-024.dll
CHANGED:
- Fixed crash when closing - I hope!
- MP3?
- O skin
PostPosted: Fri Feb 05, 2016 10:36 am
Unfortunately not here on my machine :oops: Still get the error message after closing...
PostPosted: Fri Feb 05, 2016 1:00 pm
Doesn't happen here. Please tell me: Does it happen immediately when you try to close it, or does it block for a while first? And is the Stereo Tool window still visible?
PostPosted: Fri Feb 05, 2016 1:33 pm
Ok, never mind, I found the cause!
So, I had added some logging to find the cause of a hangup earlier. But I hadn't removed that logging... and it was writing to a place that exists on my harddisk, but probably not on yours.
PostPosted: Fri Feb 05, 2016 10:33 pm
I would be just happy if the next release
- fixes the distortion of (mostly) piano instruments if voice protection in the classic multiband is used
- and PNR settings in the VST plugin work without saving it in (temporary) settings before hitting "render" in Wavelab.
... and these are not new features I request, just that existing features, that are the reason for me buying the licenses, work.
PostPosted: Sat Feb 06, 2016 12:30 am
7.85 BETA025
Windows stand alone: http://www.stereotool.com/download/ster ... 85-025.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-025.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-025.dll
CHANGED:
- Voice protection in classic MB is broken. Check what changed. (Code should not have changed at all).
- Loading old preset from before Analog mode was added apparently loads in Analog mode!
- MP3?
- O skin
PostPosted: Sat Feb 06, 2016 11:45 am
when i activate the exiter..............even after a factory reset....
Groet
