Post new topic  Reply to topic  [ 132 posts ]  Go to page Previous 110 11 12 13 14
PostPosted: Thu Aug 02, 2012 9:53 am
RELEASE CANDIDATE
Stand alone: http://www.stereotool.com/download/ster ... 32-021.exe
DSP: http://www.stereotool.com/download/dsp_ ... 32-021.exe
VST: http://www.stereotool.com/download/vst_ ... 32-021.dll
Cmd: http://www.stereotool.com/download/ster ... 32-021.exe
Linux cmd: http://www.stereotool.com/download/ster ... ETA632-021
Linux GUI http://www.stereotool.com/download/ster ... ETA632-021
DSP declipper: http://www.stereotool.com/download/dsp_ ... 32-021.exe
VST declipper: http://www.stereotool.com/download/vst_ ... 32-021.dll
Older changes:
- Bass sensitivity clipping level drop: If there are both mids and highs, the drop is a bit less strong than before
- Bass sensitivity clipping level drop: Determining more precisely when the clip is needed. So instead of dropping the bass the whole 4096-samples block, it's now only dropped at the locations of this block where there really are mid/high freqs
- Bug reported by Phoenix ( viewtopic.php?f=15&t=4235 ) should be fixed.
- BS412 also needs a max deviation (+/- 75 kHz) display --> Added
- BS412 sometimes caused drops of upto 2.5 dB. This is preset dependent. --> Adding a slider with which you can specify the amount of headroom; by lowering the output level by 0.05 dB the margin for error is already increased by 50% which seems sufficient. Test if adjustment adjust compressors properly.
- Also adding a BS412 slider with which the max deviation can be lowered; this way you can create a denser sound (apparently many commercial stations like that even though they don't gain any loudness) and it protects against spikes when the sound card or path to the transmitter isn't perfect (reason: Many current processors usually clip the signal at around +/- 50 kHz instead of 75, so in many cases the path to the transmitter doesn't have to be perfect). (Partially done, to be added: BS412 must take clipping into account; clipping level adjustment for pilot/rds).
- Something is broken in latency 512.
- Different up speeds for louder end result
- Sound card adjustment for low freqs needed (that was on my todo list anyway, but I'm moving it to the top now).
- Slightly changed sensitivity behavior (les steep drops and rises of bass). Not sure if this is the best possible solution: Alternative might be to let the bass drops start and end INSIDE the area where loud bass is present, or do the same as now but limit the maximum change speed.
- Made tilt configuration a bit easier (less steep changes at the extremes)
- 2nd RC slider is saved now
- Added displays so you can see what is being sent out to the sound card (including calibrations)
- Changed clipper distortion masking filter, this version should have slightly less distortion than the previous one but almost the same amount of highs.
- Added 2 extra sliders to control the distortion masking. Increasing the 1st or decreasing the 2nd increases the amount of highs. The goal is to find a combination of values which allows the highs to pass without adding (too much) distortion.
2nd slider determines how fast something is determined to be a tone instead of hiss - for tones I don't allow more distortion than before. First slider multiplies the calculated effect (that is, it multiplies the allowed amount of distortion, which doesn't mean that it will actually be used or lead to louder highs).
- Found and fixed several bugs in the clipper (hole punching by loud highs should be reduced).
- Allowing some extra very brief distortion to reduce hole punching by loud highs.
- Improved behavior of Highs Priority to avoid volume drops.
- Improved de-esser
- Cleaned up Loudness panel (removed some things that are no longer needed).
- Added de-esser slope slider. Set it higher to reduce the de-esser effect for highs that are not very loud.
- Added Carbon Coder plugin with multi-pass R128 support
PostPosted: Thu Aug 02, 2012 1:34 pm
And - it's released!
viewtopic.php?f=14&t=4311
