Post new topic  Reply to topic  [ 155 posts ]  Go to page Previous 112 13 14 15 16 Next
PostPosted: Tue Nov 21, 2017 1:25 am
No problem. It may take some time anyway for it to occur again. I've released version 8.54, since this issue must have been there before as well - as soon as I have a fix I will release a new version though.
PostPosted: Tue Nov 21, 2017 3:32 am
can you add a user friendly button, "more or less processing"?
also tube effect?
maybo an idea to make also a mini version, compact for light users... (only private for ex)
otherwise, good work! :)
PostPosted: Tue Nov 21, 2017 4:16 pm
Like in a sh..ty Optimod? :mrgreen:
This "switch" works -in my opinion - a little bit like Optimod's "less-more":
Marcin
I'm sorry for my bad English. I learned it by watching the cartoon netwoork in the 90's as a child. :mrgreen:
PostPosted: Wed Nov 22, 2017 1:38 am
Hans, can any of these recent improvements/features be added into the PerfectDeclipper tool? Perhaps the improvements in the delossifier? Any framework or base code improvements? Any chance the stereo/azimuth section could be added?
Thanks!
PostPosted: Wed Nov 22, 2017 12:24 pm
Just one request.
Can you make RDS frequency adjustable?
Like Airomate software can adjust it?
And play RDS only on one channel as option?
Idea of this is that you can get RDS from *any* sound card this way.
It's dirty and bad way, but it's possible. And great for experimenting with a Pi3 device.
PostPosted: Wed Nov 22, 2017 12:32 pm
hi Hans
you have here over 10000 members....eeee you have 10000 ..i want this or that..good luck :lol:
PostPosted: Wed Nov 22, 2017 12:33 pm
oh sorry i forgot about the new version ...it sounds very nice...
PostPosted: Sun Nov 26, 2017 4:36 pm
I've been testing StereoTool 8.52 ALSA on Ubuntu 16.04 on 64 bit and have been running into some issues on newer versions of the binary. Sometimes when StereoTool is started from a script, the program will run and nothing displays. Processing occurs, although nothing displays from the GUI.
I've set the DISPLAY variable and it has no influence. This also appears to be somewhat random behavior.
This looks to have happened in more recent versions (>8.22). Here is the startup sequence. It is the same for the times it works and when it does not.
Thimeo Stereo Tool 8.52 (for Linux with Jack) (C) Hans van Zutphen, 2001-2017
ALSA lib setup.c:548:(add_elem) Cannot obtain info for CTL elem (MIXER,'IEC958 Capture Switch',0,0,0): No such file or directory
ALSA lib pcm.c:2266:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2266:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2266:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Connection refused
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for 4294967295, skipping unlock
Opening X display .
Setting priority to 94
Thanks.
Brian
PostPosted: Sun Nov 26, 2017 4:54 pm
Hi Brian,
I have seen that here too on some Linux distro's. I have no idea what's causing it yet, in the latest versions I have a loop that retries to open the display, but that apparently doesn't solve it.
PostPosted: Tue Nov 28, 2017 3:01 pm
Nobody noticed that the documentation page is gone with the wind?
