Post new topic  Reply to topic  [ 209 posts ]  Go to page Previous 112 13 14 15 1621 Next
PostPosted: Wed Aug 16, 2017 2:42 pm
Ok clear. I just sent you an update for that license.
PostPosted: Thu Aug 17, 2017 1:03 am
My wife will murder me if I spend that much to buy the new license... I'll save up and get it though.
but in the meantime, we can use the features with what, a notification every 4 hours? Or is it longer/shorter than that?
Cheers!
PostPosted: Thu Aug 17, 2017 2:29 am
:roll: Same here! :D
I was hoping for an early purchase discount to justify the purchase to my wife.
My Birthday is today... Is there a BD discount? or a senor citizen discount? :lol:
PostPosted: Thu Aug 17, 2017 4:18 am
Cheers!
I think it's actually 12 hours.
PostPosted: Thu Aug 17, 2017 9:14 am
I can live with that for a while! Thanks :-)
PostPosted: Thu Aug 17, 2017 7:16 pm
Got it and it worked perfectly. Thanks Hans !
PostPosted: Sat Aug 19, 2017 9:26 am
8.41 BETA049.
I had a problem uploading the files, here's a WeTransfer link with all the files in it:
https://we.tl/3URFTcNGF4
- FM Demodulator reported to be broken (must be the compiler switch again... grrr.... -> No, was caused by change in IPP!
- AM clipper is now always oversampled
- Allow moving equalizer between MB's
- Allow moving BB before last MB
- SST: Couple Hard Limit to clipper on/off
- SST: QoS dynamic DLL -> Werkt, maar QoS niet??
- SST: Network: Add "Interface" selection. Also priority?
- SST: Add Stereo Image phase filter - somewhere. Under AZIMUTH (rename it to Phase or something)
- SST: C-QUAM divide by 2 issue
- SST: Bass Boost: Relax limits on frequencies
- GUI doesn't work in some of the versions of 046
- Disable Pre Limiter display in limiting mode.
- Share PEQ, attack/release?
- Move Spectrum Control and new AGC out of "Experimental" tab, and allow licensing. --> Button to buy it will be added to the website on Monday!
- Show Spectrum Control and new AGC in bottom display
- Optimize limiter
- Allow using bass distortion in bass clipper when used for final limiter.
- Limiter display freeze
- Add pre-AGC classical music thing
- MicroMPX add display for packet reception todo add reset packets, fix timing, show current playing position
- Add "Advanced Dynamics" to license overview screen
- Finish pre-AGC classical music thing
- SST: Make list of new ID's
- 64 bit Hard Limit is working again
- Meter for Limiter is no longer frozen.
- 9sg - update to latest code
- Old web interface bug fixes
- 9sg 1 thread.
- Add bass clipper + final limiter for testing for streaming, to figure out once and for all if it's useful or not.
- Final limiter: Make speed depend on amount of bass clipping.
- Final limiter: Fix going though chunks.
- Spectrum Control: Abrupt Change Protection could overract because it ignored certain settings.
- Spectrum Control: ACP can overreact!
- Spectrum Control: Why is kick so fast?
- All compressors: Attack/release behavior in the new RMS mode was wrong, now fixed. Result is more consistent and movements are less sudden.
- Compressor inverse-Covfefe
- AM stereo downmixer 9
- Show backup input is active - change color of input level meters
- Final limiter: Put in separate file, so I can test it separately.
- Final limiter: Make own settings page. Lots of settings needed...
- Final limiter: Make it work for Quality != 100%, Latency != 4096
- MicroMPX web interface
- Fixed crash when changing number of bands in Spectrum Control.
- Add Parametric EQ to AGC 2
- RDS: 8 character words with <| go wrong
- RDS: Empty fields - remove?
New "Experimental" section, containing:
* NEW AGC
* New Spectrum Controller (replacement of Power Bass/Power Highs), adjusts the spectrum BEFORE the AGC, without affecting dynamics or loudness.
The Analog compressors now have new "Max ratio" and "Max ratio at" settings to have dynamic ratio's depending on how the amount of attenuation.
- Fix crash
- Check FB^2 ratio - Found fixed for NCME
- Make copy of Adjustment and only turn of if MAIN drops far enough. Should get rid of temporary rises (Abba)
- Fix "Shape" in new RMS mode (just square it?)
- Add Sudden Jump Protection (directly to compressor if possible)
- Fix Triple Normal Output separate processing clipping level if pre-emphasis for FM is disabled.
- SJP: Fix Attack speed (don't use weird Shape)
- SJP in SC mode broken in MULTICORE mode.
- AGC: Gate before Drive
- SJP: Compensate for window edge
- SJP: Remove dependence on latency setting (2048)
- SJP: Test at lower latencies: 4096, 2048, 1024, 512, 256, 128
- SJP: Better lookahead. NO. Good enough.
- AGC: Make lookahead depend on SJP on/off.
- Dynamic ratio: Weird behavior with 1.001:1 as start.
- ACP: Add On/Off in SC.
- SJP: Channel merging: Fix display
- Fix Max Ratio in GUI (break out in separate subpanel)
- SJP: Auto-calculate Level Boost
- SJP: Remove dynamic ratio and add asserts.
- SJP: Add support for ratio
- SJP: Auto-recover when close to target, so Level Boost is less critical -> Not needed I think?
- Test compressor behavior, compare with 8.40 and verify no changes
- Add licensing code (SC, Dynamic Ratio)
- SC ACP: Speeds should not affect it!
- Switched to a new compiler, slightly better performance (+3%)
- Improved NAN recovery handling and fixed 2 possible causes of NAN's
- Added maximum threshold to the compressor, it doesn't do anything if the input exceeds that level.
- SJP: Weird stuff at very low latencies with SJP levels, goes up and then down sometimes. -> 1 bug fixed, now remaining issue is level difference. THAT SHOULD NOT BE THERE though!
- Stereo Image was broken in BETA049
- Name "Spectrum Controller" -> Rename? DONE, now called Auto EQ
- NAB! LW!
- Linux version crashes in latest Debian (Jack compatibility issue?)
- MicroMPX web interface version: Make sure that all ranges are correct and everything is stable when changing settings. -> Mathijs & Matthijs
- SST: Rename Auto EQ
- SST: Ohio Valley and Blue Steel use Pre Amp
- SST: Fix Bass boost frequencies in SST
- Old web interface avoid reload OR pass GUID. Right now top presets list is flashing.
- Old web interface: Text color in check boxes and buttons doesn't update
- Old web interface: Original right load can be messy. Load left first?
- Old web interface: Fix display of vu meters, also for SC
- Web interface reuse old numbers
- Add new presets!
- ladspa? r.co (Also AU & ProTools)
- Smarter stereo-to-mono conversion (only when needed). Use amount of reduction instead of maximum degrees!!!
- Optimize Spectrum Control and AGC 2
- Update RDS encoder to Mathijs' filter.
- ADYEN
- Growling bass (add to True Bass as post filter, compare with https://www.refusesoftware.com/lowender ).
- RDS: Make note in help about shared drives. Also send to Omnia.
- Try new stereo widener idea
- SST: Make it switch to backup input when the normal/FM signal switches.
- Make compressor with alternative ratio implementation
- Test clipping
- Improve UECP ASCII mode for Magic RDS (just handle \n's inside strings)
- RDS UCEP: Put a timeout on the fallback to default settings. Some programs close the connection immediately.
PostPosted: Sun Aug 20, 2017 1:01 am
Hanz, possibility to move eq after multibands is all i can dream about.
MBs changes spectrum balance over time, in this case it will be cool feature to have absolutely static instrument.
Or maybe add 2nd EQ? Before and after MBs?
PostPosted: Mon Aug 21, 2017 4:03 pm
Hi Hanz,
It seems that Paypal redirect after paying to a bad url:
Not Found
The requested URL /webapps/:/stereotool.com/ was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
PostPosted: Mon Aug 21, 2017 4:16 pm
I just checked the settings in PayPal which state that you should be redirected to http://register.stereotool.com/thanks/ . Which works fine here (it still uses the old site design).
