Post new topic  Reply to topic  [ 172 posts ]  Go to page Previous 112 13 14 15 1618 Next
PostPosted: Sun May 02, 2010 10:49 pm
i have here 1280x1024...
Other windows are from other programs .. like firefox, notepad, winamp...
PostPosted: Sun May 02, 2010 10:59 pm
Performance is still OK.
Marino: After thinking a bit more about what I saw in your log files: The Stereo Tool DLL isn't even mentioned in the logging, nor are the DLL's that are loaded by Stereo Tool. This might (MIGHT!) indicate that it's actually not a problem in Stereo Tool, but in Station Playlist. The DLL is actually loaded and unloaded 5 times by another process of Station Playlist during startup without any issues, but the loading from the Engine process fails.
PostPosted: Sun May 02, 2010 11:23 pm
If this happens, can you make the window smaller again? Or is the minimum size locked to the new size?
PostPosted: Sun May 02, 2010 11:28 pm
i can always make it default (smaller)...
i am trying to force ST window to do that again .. but with this beta i still can't.
PostPosted: Sun May 02, 2010 11:36 pm
Bug found.
When latency is at 512 and i open a preset with latency of 4096 the program freezes and sound hangs.
I previously saved these presets with a latency of 512 and now they are all 4096 when i open them.
When i change it back to 512 save them and then load them they're back at 4096.
If i first click 4096 and then open the preset it don't hangs.
PostPosted: Mon May 03, 2010 12:03 am
Bug found.
1. Quality, latency and screen update speed are not part of the preset - they are part of the global configuration of Stereo Tool. BUT that means that they should NOT be reset when you load a preset file from disk. This is a real bug that really needs fixing before I upload anything. Will post an update later tonight... :cry: :cry: :cry: :cry: :cry:
2. I've tried to reproduce the hangups here, but so far with no success. So:
- Which version of Stereo Tool are you using?
- Is this what you do? 1. Set Latency to 512. 2. Load a preset file --> hangup? If so, does it happen occasionally, or every time?
I hope problem 2 will be solved when the latency doesn't jump back to 4096 anymore when you load a preset. Although it does indicate a problem somewhere.
PostPosted: Mon May 03, 2010 12:19 am
I use the latest version Stereo Tool version 5.00(May 2010), i downloaded it again tonight and installed it over the 5.00B version.
Yes i change latency to 512 and then load the preset again, it also happens if i load a different preset. Most of the times it crashes, but sometimes it goes good.
PostPosted: Mon May 03, 2010 12:27 am
By the way, is this the Winamp, VST or stand alone version?
Could you try the following:
1. What happens if, instead of loading a preset, you press RESET?
2. If you're using the Winamp or VST version: Does it also crash if you load a preset if no audio is playing? If so, does it crash when you start playback again?
PostPosted: Mon May 03, 2010 1:39 am
eldoradofm: I've now uploaded a new version where loading a preset doesn't set the latency anymore. Uploaded as BETA (use the links in the first post of this thread).
I hope this also fixes the crashes (it probably hides them instead of really fixing them, but for now that's good enough for me...)
PostPosted: Mon May 03, 2010 2:02 am
I use the stand alone version.
Tried the new version. It still hangs sometimes when loading presets. It sometimes even hangs when selecting the same preset a couple of times. I removed stereotool and reinstalled it. Sometimes it also hangs when pressing reset.
