Post new topic  Reply to topic  [ 424 posts ]  Go to page Previous 111 12 13 14 1543 Next
PostPosted: Thu Jul 28, 2016 1:34 pm
- Type IP in web site
Windows stand alone: http://www.stereotool.com/download/ster ... 01-015.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 01-015.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 01-015.dll
Known issues:
- Affinity for LQLL
- CPU usage for all threads and for LQLL threads
- Display needs to be updated for all processing threads
- Display updates must happen in correct order (weird noise jumps otherwise)
- Generate UIDs and use link
- Password for login?
- Quality between 100 and 150%?
Later:
- Service
- TODO: Add exception if ignoring too high VST parameter numbers (Audacity bug!).
PostPosted: Thu Jul 28, 2016 11:41 pm
Hmm i just checked (beta13) when i rise input absolutely nothing happens, except light-green bars.
Ah. Ok. Radiofreak also found the issue - if you set the input sample rate higher than 48 kHz it boosts the level.
Hmm no.. and i am always at 48kHz. Tried 96 too.
PostPosted: Fri Jul 29, 2016 2:59 am
It was fixed in 014. (At least I think it was - I just realized that I kinda forgot to test it...)
PostPosted: Fri Jul 29, 2016 11:27 pm
Nope testing beta 15, all same.
PostPosted: Fri Jul 29, 2016 11:31 pm
Hm? Radiofreak has send me a PM that he tested it and it was fixed.
PostPosted: Sat Jul 30, 2016 12:16 am
input 0dB
Input +11dB
Declipper bar should rise, AGC at +11 should attenuate more, etc
PostPosted: Sat Jul 30, 2016 9:52 am
8.01-14:
Output is overdriven brutally.
8.01-15:
Everything fine, In = Out.
Full factory reset, except setting sample rate to 192 kHz under Sound cards -> Sample rate
PostPosted: Sat Jul 30, 2016 10:21 am
I think Bojcha`s issue is not the same as radiofreak !
Bojcha uses the gain slider, radiofreak no . So Bojcha`s bug is "another one" :)
PostPosted: Sat Jul 30, 2016 11:40 am
Ah! Yes, the Gain slider was broken - I fixed that yesterday but I haven't posted a new build yet. Coming today!
PostPosted: Sat Jul 30, 2016 5:06 pm
- Gain works again
Known issues:
- Set affinity for LQLL
- Display CPU usage for all threads and for LQLL threads
DONE:
Later:
- Service
