Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 111 12 13 14 1559 Next
PostPosted: Tue Feb 02, 2016 1:44 pm
I think this "polar" thing is very very unneeded one ! Looks like it causes bugs wih other things. So why this thing must even exist ?
I propose one time the very old classic multiband and all old stuf to be removed. There was enough versions with them and everyone who wants them - to use old version anyway.
IMHO it is often a basis for discussion to add a new Feature or not. I also never heard about polar Stereo before. but after reading the posts of radio700 here
viewtopic.php?f=16&t=6233&p=33031#p33031
then i would say it is useful. I know this guy, what he tells is true and based on his own experience.
The classic multiband sounds nearly completely different compared to the newer ones. It is fully ok to "freeze" it like it is now and hide it in the GUI if not used, but remove? Not shure...
Perhaps there are People using the classic MB but want to test or use other new features of ST...
It doesn't disturb if it is available but hidden i think...
PostPosted: Tue Feb 02, 2016 5:02 pm
I`m not saying it because i hate classic MB or similar . I`m saying it because for new things, there is no room for vertical options, there is no space for the new options in panels . ST is getting on another level and must be only with "next level" options.
That is why i said there is plenty of versions that include the very old stuff - i think they are extremely enough
.Think about it - if Hans add 5-10 features and you are n Extreme tweaker mode ?! What will be ? No room for your brain to think what to edit. Well it`s been 5-6 years now with all the stuff(with new ones all in one)
It`s time to make ST up to date clean GUI featured program.
You say that we must fill the glass even when it overflowing ?
PostPosted: Tue Feb 02, 2016 7:36 pm
No further changes.
I have now again intensively tested the beta. The results are in any case very well, but I have in many respects as a scrape in the higher frequencies. But that does not concern all the songs. This occurs especially whenever much speech is present. The pitches generated sound somehow unclean and not crisp. Then another question: Is it possible that you can fit a few more configurations in the upcoming Beta? You mentioned something about a hard-coded frequency limit, and some of max 1 octave. Would it be possible that you do it configurable? I would in fact like to test further, and with the available options you can not adjust as much. Thanks in advance!
PostPosted: Wed Feb 03, 2016 12:36 am
bug: The latest VST (and maybe older) in 7.85 beta makes the left channel louder with nothing enabled at all.
PostPosted: Wed Feb 03, 2016 12:57 pm
I spend two years tweaking the "classic multiband" for my multiple settings. I have not the time and the nor knowledge to do the same for the new multiband feature again.
Additional to that the new multiband would be a step back for me, because I cannot tweak the settings on one page (which I am constantly doing when I remaster tracks with Stereotool as VST) and I have no voice protection setting. And for newcomers the classic multiband enables them to easily understand the feature while the new one leaves newcomers out and makes Stereotool exclusive to experts. A good software makes complex processes easy to understand, so it is inclusive to many users, which many of the "classic" features did but the new ones do not anymore - Steroetool becomes more exclusive to experts. So there you have also a step back. Transfering my old settings for classic multiband to the new one is currently just a waste of time for me - I gain nothing from it plus loose functionality for me.
Besides: I bought licences, I gave money, so I am not a free leecher. I would appreciate if for my money I am able to use my own settings which massivly use the classic features - and I spend months and months to create - with new features (like the repair options and stereo options). Its a service for the users of the software.
Unfortunatly the voice protected setting creates clipping/distortions in the current versions, so I have to use 7.03 and 7.84 as an VST chain in Wavelab to remaster tracks. It would be nice if I could use the current version in Winamp without the distortion problems too.
I would switch to the new multiband if:
- there is an automatically conversion of the classic settings to the new, so they sound exactly the same under the new multiband.
- I can control the voice volume like with the old voice protection setting
- I have the basic settings for daily tweaking on one page like with the classic multiband.
Until then I stay with the classic one, because there is nothing to gain for me.
PostPosted: Wed Feb 03, 2016 2:25 pm
I have no plans to remove it, but I don't want new people to use it because it just sounds far less good than the new one. There were several 'problem tracks' that on ALL the Classic multiband settings would sound bad.
It might be a good idea though to combine the settings for the new MB in a single window when you're in Basic mode. In fact, by removing things that aren't really needed anymore, I'm slightly moving towards having less settings because it's just too overwhelming now.
Also I'm currently adding help texts for all the sliders and buttons, which can be made visible inside the GUI.
PostPosted: Wed Feb 03, 2016 3:02 pm
As a vst user of stereo tool an observation is that true bass and bass boost usually don't sound good on mastering a song so the option to turn these on or off is good.
PostPosted: Thu Feb 04, 2016 12:59 pm
7.85 BETA022
Windows stand alone: http://www.stereotool.com/download/ster ... 85-022.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-022.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-022.dll
CHANGED:
GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Exciter: Improve further, and make it configurable.
- Add Polar stereo viewtopic.php?f=16&t=6233&p=33031#p33031
- MP3?
- O skin
PostPosted: Thu Feb 04, 2016 1:51 pm
Nice, the issue with Polar Stereo is gone now!
The new Tooltips are also very nice, but there seems to be an issue: when a tooltip pops on, and I move the mouse cursor afterwards, the GUI freezes :oops: (using 32-bit standalone).
Edit: This happens sometimes only, not always...
PostPosted: Thu Feb 04, 2016 2:34 pm
Ah, confirmed. Seems to depend on the window size. Will check!
Edit: Solved. Was a threading issue. Next beta will be ok again.
