Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 345 posts ]  Go to page Previous 111 12 13 14 1535 Next
PostPosted: Fri Jul 17, 2015 8:31 pm
Latest version ( may be not only) has some distortion issue !!! Very bad .
If interested - i can do a screenshot. This was not introduced in prevous betas and versions.
I don`t want to take back to check from what beta is .
When, and what type of distortion? With what settings?
PostPosted: Fri Jul 17, 2015 8:59 pm
Intermodulation ddistortion .
And i think it`s goes bad with frequency up . The most highs looks like this ( 14500 Hz)
It`s not caused by any options . I try to enable/disable all the new ones , but....
Only when Enable "ignore high freq" , this is lowered but still there . But when enable it i already mention that synchronization with output parameters goes crazy .
Edit: This version gives me 2% Cpu increase.
PostPosted: Fri Jul 17, 2015 9:10 pm
Composite clipper (normal without leif`s) , causing phase rotation about 90 degrees. ...
Absolute mess.
PostPosted: Sat Jul 18, 2015 4:29 am
Interesting one - "soft focus"..
PostPosted: Sat Jul 18, 2015 12:01 pm
Hm, I see the distortion for high tones (which should not have been there obviously), but no phase rotation. Will fix those tones first.
PostPosted: Sat Jul 18, 2015 3:47 pm
Turning "Protect tones" on removes the distortion. Something is wrong here... for now, turn that on.
PostPosted: Sat Jul 18, 2015 4:50 pm
1. Problem is in Advanced clipper somewhere . When i disable it , this distortion stopped.
2. i got NAN output when enable the "Smothie highs early" in HIGHS panel of Advanced clipper.
This error is looping and cannot be closed.
3. Phase rotation in Composite clipper is caused when Strictness is above 10 ! I mean original option ( not leif`s)
When Composite Strictness below 10 - second picture.
When Leif enabled - same thing.
Important ! - Signal at input of ST is with NO phase degrees shift.
PostPosted: Sat Jul 18, 2015 5:05 pm
Looks like sample/resample bug . May be the old bug with MPX display is related .
Yes, you fixed the display bug but .. may be you fix only the display according to the new code modifications.
For sure you must search the bug in Advanced clipper.
PostPosted: Sat Jul 18, 2015 5:45 pm
Both issues confirmed here. Will start looking...
PostPosted: Sat Jul 18, 2015 9:08 pm
hello good work ı wanna say something
you're trying to produce clean and beautiful stereospecific signals ?
my idea is to use the processor of the computer for it
maybe you should produce a special sound card for this program remains then everyone happy and so you buy
They need a very high gain crystal
I forgot to mention in the sound card should have a fast processor that prevent long delays and increase quality
Produce like a 284 kHz 64-bit sound card
