Post new topic  Reply to topic  [ 154 posts ]  Go to page Previous 111 12 13 14 15 16 Next
 Post subject: Re: Stereo Tool 7.41
PostPosted: Fri May 09, 2014 4:56 pm
Anyone to feel few % (2-3) more CPU ? I mean without flat..
PostPosted: Fri May 09, 2014 5:32 pm
Are you using the stand alone version with ASIO? If so, please try what happens if you go to the ASIO panel, and set the Marian Win7 Driver Fix slider to 0.
PostPosted: Fri May 09, 2014 5:37 pm
I`m not using the ASIO and i don`t have Marian card . So i can`t test this one, sorry
P.S: I set the slider to 0 but no difference. Before was around 12-13% , now is 17 with same preset all the versions. I think there is a few % raise. Sometimes i have different load and that is why i ask others to say what they notice.
PostPosted: Fri May 09, 2014 6:41 pm
edit:
not sure about it anymore.
The Power of Sound
PostPosted: Fri May 09, 2014 10:31 pm
edit:
I didn't see this before the edit - should I ignore this post?
PostPosted: Sat May 10, 2014 2:31 am
I tried the DSP plugin and here the difference between 7.41 and the latest beta is less than 1%.
PostPosted: Sat May 10, 2014 10:04 am
edit:
The pop-up only comes up with one preset wich already has composite enabled, other presets with composite enabled doesn't show this.
probably because some settings of my own.. so ignore it.
The Power of Sound
PostPosted: Sat May 10, 2014 3:45 pm
New beta: BETA742-017.
Windows stand alone: http://www.stereotool.com/download/ster ... 42-017.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 42-017.exe
Windows VST 32: http://www.stereotool.com/download/vst_ ... 42-017.dll
Windows command line: http://www.stereotool.com/download/ster ... 42-017.exe
Changes:
- Maybe change band 2 band shape (feedback Bojcha) -> apparently not
- Optimize new MB flat (1 FFT instead of 9) - DONE
- Old Flatness slider must be disabled when 'Flat tops' is enabled; other checkbox right to 'Flat tops' might be removed again. - DONE
- Fix Perfect Declipper keyboard input so I can also release a new declipper version
- Check performance DONE, difference is less than 1%
- Added a lot of new presets.
Old Changes:
- Fixed the compressor Knee bug in 015.
- Added the first few new presets, and removed a bunch of others
- Lots of small issues that might cause problems on different systems/plugin hosts etc. resolved: Rounding error in compressors.
- Added 'Flat tops' in Multiband Compressor and Natural Dynamics, with different band contents and improved crossover/flat output behavior.
- Added experimental DeLossifier (MP3 artifacts removal filter). So far it only reduces pre-ringing a bit.
- AM support doesn't work properly: viewtopic.php?f=2&t=5512&p=24635#p24635 FIXED
- Linux version crashed - FIXED
- Crash in 64 bit VST plugin in compressor - SHOULD BE FIXED NOW
- Hangup with Marian Windows 7 driver: WORKAROUND AVAILABLE
- Added Marian sound card driver hangup workaround
- Added locking to MM audio I/O code to protect buffers
- Potential rounding error in compressor (which could lead to all kinds of issues) fixed
- Deemphasized audio didn't work properly under all circumstances in 7.41, fixed again.
- AM Assymmetry in combination with FM enabled again
- Declipper behavior at extremely low latencies (256 samples or less) improved
- Code improvement: Initializing some values that were never initialized before
- Code improvement: Several 'Division by 0' situations (which are masked so they didn't cause problems) are now completely removed
- Add presets, waiting for Thorium6 update/web version, and need to set correct levels (generic presets, BS412)
- Change version number to 7.42
- Release
- Hangup with Marian Windows 7 driver: attempt to pinpoint the cause together with Marian.
- Dotted area in ASIO input buffer (GUI only) TO BE FIXED
PostPosted: Sat May 10, 2014 4:06 pm
Delossifier i think there is something wrong .
I ones change the channels to the right configuration according to my old suspect of channel changed. Now when i press "Left channel only" test and the difference checkbox . It plays only the RIGHT channel. Is there something wrong ?
...May be it`s the Difference only on the left channel ? Is this the right explanation , so that`s why only Right is played . If so , ignore this post.
PostPosted: Sat May 10, 2014 4:14 pm
Thorium6
Stereo enchancer,ND,and De-clipper off?
Garbage in is Garbage out !
