Post new topic  Reply to topic  [ 190 posts ]  Go to page Previous 111 12 13 14 1519 Next
PostPosted: Fri Jun 28, 2013 9:59 pm
Sometimes channels are swapped in last standalone, restart fixes it. Normal output no asio. Not tested FM.
Ok, this is new right? :(
This type of issues is actually one of the most difficult bugs to find, hence also to fix (although - I did add a lot of test code in the debug version for this the last time I had a similar issue, so that should help). Any idea when they swap?
PostPosted: Fri Jun 28, 2013 10:04 pm
Linux version with FM (including stereo and RDS) and Low Latency audio:
http://www.stereotool.com/download/ster ... ETA724-021
ST does not "see" any signal in my case - I feed music into the in ports and ST remains silent. Happens at 44100 and 192000.
PostPosted: Fri Jun 28, 2013 10:19 pm
Will try to discover.
PostPosted: Fri Jun 28, 2013 10:24 pm
I cannot really work on or further test the clicking before next Tuesday (that's when I'll be back in my office, where my test system is). So I won't do too much this weekend.
Slow down and keep relaxing! You did a great job so far, so I send you some money for a coffee-break ;)
PostPosted: Fri Jun 28, 2013 10:37 pm
The input and output bars are green?
PostPosted: Fri Jun 28, 2013 10:38 pm
Will watch a bad B horror movie :)
PostPosted: Fri Jun 28, 2013 10:44 pm
Yes, and weirdly enough, the output bar is only filled (statically) by 75%.
PostPosted: Fri Jun 28, 2013 10:52 pm
Fixed crash on minimize.
Improved performance a bit (especially on GUI redraws).
http://www.stereotool.com/download/ster ... ETA724-022
PostPosted: Fri Jun 28, 2013 11:23 pm
Nice, works! Now I can change the workspace without going off-air :)
Have fun :mrgreen:
PostPosted: Sat Jun 29, 2013 12:04 am
Now found that Synchronize does not work..
