Post new topic  Reply to topic  [ 180 posts ]  Go to page Previous 111 12 13 14 1518 Next
PostPosted: Tue May 29, 2012 5:09 am
With the 13A version, the core work with similar charges (the core 2 has a little under load, but the difference is ~ 10-15%).
Also improved the overall CPU load in a ~ 10%, now the average CPU load was 50% above the 60% ​​(same preset).
Good job! ;)
P.S.: I have not compared with version 13.
by GAP
"Less is More" (Bob Katz)
PostPosted: Tue May 29, 2012 5:10 am
Not big diff, but "A" version is with less cpu load, i guess that version will stay.
PostPosted: Tue May 29, 2012 9:20 am
The difference in CPU load should not be that big... But I'm going for the A version indeed. Which means that I can now remove some now obsolete code.
PostPosted: Tue May 29, 2012 9:41 am
Have you had an opportunity to consider more test platforms? One newer, and one older, specifically with an older K8-core AMD (I think Bojcha's X2 system is K8-based)?
Possibly it doesn't matter AMD vs. Intel, but more specifically less than 2MB L2 cache per core.
All I know is that when you quote single-digit levels, I can generally double whatever you quote, at a minimum. For example, you quoted 6%. I'm not sure if that is a delta or absolute, but I can tell you that same settings gives me a 25% delta (25% increase), or about 10% absolute (40 -> 50 in Task Manager, sometimes as high as 55).
PostPosted: Tue May 29, 2012 10:25 am
Uhm... With the *new* settings I actually measured a *decrease* of 6% (11.2% -> 10.6%) on my system. With the old settings it's a 3% increase (so to around 11.5%). Are you getting an increase with the new settings too??
Another (small) CPU load reduction step is coming up.
PostPosted: Tue May 29, 2012 11:21 am
The "new" settings are essentially the same as the "old" settings. I might be seeing a 1% total variance, but that is +/- of where it used to be. For example, I'd see 35-40 for "old", and am now seeing 34-40...
I don't think you're going to see P4/K8 drop any lower than where it's at right now due to L2 limitations, unless you start disabling several things, like multiband and loudness.
PostPosted: Tue May 29, 2012 11:41 pm
Difference Between 6.30 and 6.31 - B13A is important
Definitively ST approach perfection !!!!
Congratulations Hanz, we wait the final buld 6.31
Actually we used the 6.30 in FM and the 6.31 - B13A in the for streaming webradio.
PostPosted: Wed May 30, 2012 7:17 pm
It's just me, or Beta 13A got a "sound texture" that other versions of Stereo Tool don't have? Everything sounds so much full of life, highly defined, even with bad recordings.
PostPosted: Wed May 30, 2012 9:24 pm
Hm, who knows... Bojcha and I couldn't hear any difference between 013 and 013A, but that doesn't necessarily mean that no-one can. (Does "other versions" include 013?)
Actually I have some more code changes that I made a few days ago but haven't posted yet, after reading this I guess I should post them tonight just to make sure that nobody hears a deterioration...
PostPosted: Wed May 30, 2012 9:49 pm
Well, I didn't tried Beta 13, just upgraded Beta 12 to Beta 13A.
