Post new topic  Reply to topic  [ 259 posts ]  Go to page Previous 111 12 13 14 1526 Next
PostPosted: Mon Mar 13, 2017 1:20 pm
Also new in the next build...
This is great!!!
PostPosted: Mon Mar 13, 2017 1:23 pm
Vst download does not work
Pretty Girls in your city
PostPosted: Mon Mar 13, 2017 1:27 pm
Server problem. My hosting provider is looking into it. They moved my site to a different server this weekend.
PostPosted: Mon Mar 13, 2017 2:16 pm
After switch bypass few times scopes and all gui refreshes very slow down like 10%.
Urban Junglist
PostPosted: Mon Mar 13, 2017 2:23 pm
Pi3 is 1.2Ghz (4 core) , it still can`t be enough ?
That doesn't really mean anything. There are Pentium 3's that run a 3 GHz, if you only look at numbers they would be more than twice as fast as 2 ARM cores of 1.2 GHz. The real issue is how much a CPU can do per clock cycle.. and recent Intels do a lot more than ARM's.
PostPosted: Mon Mar 13, 2017 2:24 pm
That sounds like the input sound card doesn't work properly anymore. Is audio still ok in this situation? And, are the crashes gone?
PostPosted: Mon Mar 13, 2017 4:02 pm
After this slowdown gui sound and processing is still same, only gui behave slowly.
Some crash also happened :(
Urban Junglist
PostPosted: Mon Mar 13, 2017 4:08 pm
Still in ntdll? Which Windows do you use? You're the only person who's reporting crashes (which is why I don't dare to release this version yet)...
PostPosted: Mon Mar 13, 2017 4:43 pm
Win10 x64, when it crash just ST stops and windows pop up to find solution for error bla bla... I can't get logs because I don't have access to this.
Maybe this win10 is broken I don't know but I don's see crashes from other software, so really I can't help you :(
Urban Junglist
PostPosted: Mon Mar 13, 2017 4:56 pm
Ow! So this is different from the message that you posted before? Have you not seen that anymore at least?
By the way, just getting a Windows pop-up and nothing inside Stereo Tool shouldn't be possible anymore :( Could you create a directory C:\temp ? And then check if it generates a log file there?
O, and is it stable as long as you don't use Bypass?
Can you send me your full .ini file with settings? I wonder if it's some combination of things that I haven't tested yet.
