Post new topic  Reply to topic  [ 2125 posts ]  Go to page Previous 1117 118 119 120 121213 Next
PostPosted: Thu Aug 04, 2011 12:58 am
For the future, I have a change planned that - if I'm right - should make the AGC much more resilient against volume drops caused by loud voices. Actually it's a pretty simple change - but I'm probably not going to implement it in version 6.20 anymore. Anyway, if that idea works I should be able to lower this value again.
I have some idea and it's very simple actually half is already in current AGC just some changes ... if you want to hear...
Given that description we might even be having the same idea... Tell me :-)
PostPosted: Thu Aug 04, 2011 1:10 am
Hans,
Can you play this with De-Clipper only...
http://www44.zippyshare.com/v/52908379/file.html
How can i fix this? I am on beta084.
Atleast two unwanted effects i hear.
edit:
For now this track and some others are much better when i turn on "Forcibly make restored samples higher..."
Looking at the data that I'm collecting for the reconstruction, I think the 'More' checkbox must alway be enabled to get rid of this effect. Actually, since this checkbox seems to be far more important (and needed) than I originally thought, maybe I should replace it with a slider, allowing more precise control.
PostPosted: Thu Aug 04, 2011 2:17 am
I tried making test tones with adobe audition. I tested with 53 kHz tone and 48 kHz tone. Both are set to -3dB.
In MpxTool i get exactly 100.0% with both tones, so why is there no problem when i use that? Both files played with winamp trough VAC to MpxTool.
For 48 kHz, try setting the start phase to 45 degrees. I've just tried it in CoolEdit (older version of Audition) and with start angle of 0 degrees I get a peak level of 0 dB, with start angle at 45 it's -3 dB. The RMS level is identical though (-3 dB).
Ok i just made a record of the MPX and watched that in adobe audition and i see what you mean. But for testing with MPX tool will it be an easy fix to always start at the highest point of the waveform, so you don't get this interpolation effects?
PostPosted: Thu Aug 04, 2011 4:31 am
What is with "Advanced extreme Highs protection" ?
PostPosted: Thu Aug 04, 2011 4:09 pm
BETA087:
- Declipper artifacts (Bojcha's post viewtopic.php?f=14&t=3065&p=12527#p12527 ): Added another slider to control when to stop declipping; artifacts should be gone now.
- Re-enabled Reflection. ("Stronger clipping", incorrectly named 'Limiting strictness' in the current version - fixed for next beta). So now the clipping is stricter; in other words to get the same result as before you can now select a lower 'Strictness' value. This filter has far less effect on the audio than before because it only works after most of the easy-to-remove spikes have already been removed.
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-087.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-087.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-087.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-087.dll
Command line version: http://www.stereotool.com/download/ster ... 20-087.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-087 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-087 NOT AVAILABLE
- Fix Punch
- Fix crash at program close
- Reduce Loudness CPU load
- Scopes black background?
- Add AGC start level
- Save bandpass filter order
- Optimize clipper code: Reflection, smaller overlap
- Save new clipper options (STS+VST)
- Smarter lows volume drop against highs protection: First clip using reduced highs (highs protection filter), then do it again but do NOT lower the lows below the level found in the 1st step.
- Add composite clipper
- Highpass before Multiband etc?
- Release 1 hour
PostPosted: Thu Aug 04, 2011 7:02 pm
Don`t make any records , just install SpectraPlus and with virtual cable make a real time watching of the MPX ..
For now every version indicates an overloads ...... set the dynamic range from 0 to -130 db and watch the movie :)
PostPosted: Thu Aug 04, 2011 11:59 pm
BETA087:
Still having to go to -10 to get back to same performance. Is this the extent of the optimization, or is there more?
PostPosted: Fri Aug 05, 2011 12:03 am
So far, this change didn't make it faster but gives stricter clipping results at the same quality setting.
I'm going to post an update now, where the CPU load is reduced (not drastically, but at least a bit). If this is not enough, I can make a small extra performance boost but it might start to become noticeable in the audio.
PostPosted: Fri Aug 05, 2011 12:05 am
BETA088:
- Reduced clipper CPU load (check "Take some shortcuts (CPU)" slider.
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-088.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-088.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-088.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-088.dll
Command line version: http://www.stereotool.com/download/ster ... 20-088.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-088 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-088 NOT AVAILABLE
- Fix Punch
- Optimize clipper code: Reflection, smaller overlap (more needed?)
- Release 1 hour
PostPosted: Fri Aug 05, 2011 12:39 am
Hm ok. The much higher CPU load is mainly caused by the fact that the new filter is (by default) configured to work on upsampled audio. Without that, I can go to -8 for identical performance. Unfortunately the output also looks identical (peak levels are equally high). Which is surprising: I would expect them to be lower. On the other hand, when I measure the RMS level it's about 0.3 dB higher. And for loud S sounds it's far more constant. So I guess it's still better.
Now, having said that, that's without upsampling. With upsampling the new filter is really slower.
