Post new topic  Reply to topic  [ 2125 posts ]  Go to page Previous 1115 116 117 118 119213 Next
PostPosted: Wed Aug 03, 2011 4:35 am
Hans,
Can you play this with De-Clipper only...
http://www44.zippyshare.com/v/52908379/file.html
How can i fix this? I am on beta084.
Atleast two unwanted effects i hear.
edit:
For now this track and some others are much better when i turn on "Forcibly make restored samples higher..."
PostPosted: Wed Aug 03, 2011 6:56 am
BETA085:
- When "Enable FM transmitter calibration" is OFF and you click "Calibrate FM transmitter ..." and then close calibration screen again, then "Enable FM transmitter calibration" is turned ON automatically: No longer the case, instead there are now enable buttons on BOTH the FM and the FM Calibration window.
- Use DLL name in INI file name (requested by Jazler): If the Stereo Tool DLL or EXE file is renamed, the INI file now uses that new name. This way different startup values can be loaded into different Stereo Tool instances.
- Added registration option to command line versions
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-085.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-085.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-085.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-085.dll
Command line version: http://www.stereotool.com/download/ster ... 20-085.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-085 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-085 NOT AVAILABLE
- Fix Punch
- Fix crash at program close
- Reduce Loudness CPU load
- Scopes black background?
- Add AGC start level
- Save bandpass filter order
- Declipper artifacts ( viewtopic.php?f=14&t=3065&p=12527#p12527 ): Adjust defaults or increase bass sensitivity.
- Optimize clipper code
- Add new clipper options
- Smarter lows volume drop against highs protection: First clip using reduced highs (highs protection filter), then do it again but do NOT lower the lows below the level found in the 1st step.
- Add composite clipper
- Highpass before Multiband etc?
- Release 1 hour
PostPosted: Wed Aug 03, 2011 7:12 am
@Bojcha: Hm, I thought I had covered most of those type of sounds - apparently still not completely.
Here's how to get rid of most of it (works better than enabling 'Force higher', and has less effect on reconstruction):
In "Stop declipping if apparently not clipped", increase the slider to "Often (less artifacts)", and (most important) enable "More".
As far as I've seen this should have nearly no impact on clipping restoration. I didn't put these settings so high because I thought it wasn't needed... I'll do a quick check later to see if I can avoid using higher settings here by making the filter more sensitive to loud bass sounds.
PostPosted: Wed Aug 03, 2011 11:09 am
@Hans, i think you should also mention to re-enter the registration code in stereotool again with this new version. At least that is for the stand alone version.
Also in the stand alone version the check box to turn it on/off is missing in the FM transmitter calibration window.
Also the beep tones are still not corrected in fm transmitter calibration and i don't see it anymore on the todo list. I only tested stand alone version.
PostPosted: Wed Aug 03, 2011 11:55 am
Oops, I overlooked that - the stand alone executable is named StereoTool.exe and the ini file stereo_tool.ini - I guess it might be a good idea to fix this anyway so if you do use multiple copies you don't need to register each time. Will add both issues to the todo list.
Will fix it.
Odd, I thought I had fixed that. Will check again.
PostPosted: Wed Aug 03, 2011 11:56 am
I cant run last Beta85.. i have Gaps on air :( and sounds better than Beta84. But i still vote for Beta69 with Dynamics :p
PostPosted: Wed Aug 03, 2011 1:46 pm
That's odd - BETA085 and BETA084 should have identical performance and sound the same except for the better handling of loud spikes of sound in the BETA085 AGC. If you're running the stand alone version, chances are that you're not getting the correct settings because it uses a wrong ini file to store its data in. Could that be the issue?
PostPosted: Wed Aug 03, 2011 2:57 pm
BETA086:
- Registration key written to DEFAULT ini file. And for stand alone version, ini file stereo_tool.ini is used by default again.
- FM Calibration beep tones should be ok now
- Stand alone: Check box to FM Calibration on/off missing in the FM transmitter calibration window: Fixed
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-086.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-086.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-086.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-086.dll
Command line version: http://www.stereotool.com/download/ster ... 20-086.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-086 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-086 NOT AVAILABLE
- Fix Punch
- Optimize clipper code: Reflection, smaller overlap
- Release 1 hour
PostPosted: Wed Aug 03, 2011 3:10 pm
The composite limiter is now causing artifacts with the fm transmitter calibration tones.
Is it possible to move the calibration to go after the composite limiter to avoid this?
PostPosted: Wed Aug 03, 2011 3:13 pm
@Hans... what about Beta79??.. this i have on air... I didnt try Beta84. and i register and load the same preset.!
