Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 233 posts ]  Go to page Previous 110 11 12 13 1424 Next
PostPosted: Thu Oct 22, 2015 7:56 am
"rumbling" is the right word, yes. I think it`s not ringing.
PostPosted: Thu Oct 22, 2015 11:03 am
Last beta won't start on windows 10, beta 8 no problem.
The Power of Sound
PostPosted: Thu Oct 22, 2015 11:24 am
Anyone else to have this ?
I got it after some time working. When this happened, buffer was fully filled, and Synchro was at 2.000 M1.020
Usually is at 1.000 M0.9752
PostPosted: Thu Oct 22, 2015 12:18 pm
Which version (stand alone, DSP, VST)? And do you get an error message? What happens exactly?
PostPosted: Thu Oct 22, 2015 12:19 pm
Ok, that has to be a bug in my new framework. This just happend without you doing anything?
PostPosted: Thu Oct 22, 2015 12:24 pm
I think not, i just browse in browser and do some other things (not heavy cpu load things) and when i switched to ST , saw this- including the buffer and synchro values. It was happen from time to time in previous versions , but i can`t say exactly from what .
May be when PC is some kind of busy , ST make some recalculations and buffer is getting empty , then ST "wants" to fill it or something - then this may happen.
But the answer is - yes, i was not doing anything with ST in that time. Just saw it when it`s already been happened.
PostPosted: Thu Oct 22, 2015 1:01 pm
O! So this is not new? Then it cannot be the framework rewrite, at least not what I did in the last few weeks. Do you know in which version it started? (7.73? Or starting in 7.74 beta's?)
PostPosted: Thu Oct 22, 2015 1:29 pm
I was report something similar versions ago with the buffer and CPU load, but don`t remember when.
But exactly this problem is only on this last beta 013. I don`t remember that happens on beta 008
I guess it`s related to some PC busy or when my hard drive is "constantly doing something" for about 2-3 minutes ( don`t know what ), may be clears some cache, or some windows things.
So focus only on this last beta, for now
The interesting thing is that when i saw this , task manager is showing normal load, as usual
PostPosted: Thu Oct 22, 2015 2:10 pm
I'm mainly interested in feedback about Bass In Your Face! (Which, based on my tests so far, needs some work to avoid a constant rumbling sound in some tracks - although I could kinda imagine that some people might actually like that)
Please say that this is bass which breakaway has!
Can you make an 64-bit linux version of the betas?
PostPosted: Thu Oct 22, 2015 2:30 pm
Not even close.
